Home > Technical (L322) > transmission ? |
snugg Member Since: 16 Jun 2010 Location: Maryland Posts: 29 |
I have tracked down my all comms and pulled this code "Symptom gear monitor fault General fault " from the transmission" |
12th Nov 2012 1:46am |
I hate to tell you but this symptom is the box itself. The box will need to overhauled/repaired £1000 or replaced £2000.
12th Nov 2012 7:23am |
Thanks for the reply. When i drove the truck this morning, it worked fine until i got almost to work (about a 20 minute drive). Could the trans be running too hot from a clogged raditor or may airlock in the collong system? |
12th Nov 2012 1:07pm |
Yes it is almost certainly caused by overheating due to Oil Cooler not working correctly due to a clogged lower section (lowest eight rows) of the main radiator. VERY common issue.
12th Nov 2012 1:40pm |
deleted |
12th Nov 2012 2:07pm |
Thanks once again. is there an easy way to determine if the lower portion of the radiator is clogged without removing the radiator? Or is there a way to see if the trans cooler is actually working properly? |
12th Nov 2012 2:32pm |
Yes the speed that that the radiator drains 1 litre fluid for from the drain/release plug can be timed to see if its blocked or not. You will have to search for correct times (Google or maybe on here) |
12th Nov 2012 2:38pm |
