Home > Technical (L322) > IIDTool from gap diagnostics ***Q & A ***
Page 18 of 49 <123 ... 171819 ... 474849>
daveo
hi, thanks for the help, i had the latst firmware but could not see car config, but now can..what happened was when the tool started it showed read fault, button up and went to clear fault and then up again to show configuration.. but after that nothing untill i held the button for about 3 seconds, it then jumped to the next level and so on.. showing all the other menu's, now i know its there its just a matter of holding the button just that bit longer. so now the playing carrys on..
Is the backup file in restore the one it made when the tool was first activated and does it backup all the modules to how it found them..
thanks Thumbs Up V8 facelift Range Rover Autobiography 22" wheels.
Post #150034 6th Nov 2012 8:02pm
the IIDTool only does an EAS backup on first use Dave... ... - .- -.
Post #150036 6th Nov 2012 8:08pm
daveo
so do i have to go into menu and back up again or does it only back up the EAS module V8 facelift Range Rover Autobiography 22" wheels.
Post #150040 6th Nov 2012 8:13pm
when you activate the tool ,it automatically backs up the EAS, nothing else.. ... - .- -.
Post #150041 6th Nov 2012 8:14pm
SteveMFr
Site Sponsor
actually, in the newer versions of the FW it does a complete back-up. Christian and Patrick work so fast sometimes it is hard to keep up! Razz
So to answer Daves question
Yes
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #150046 6th Nov 2012 8:47pm
Thumbs Up ... - .- -.
Post #150056 6th Nov 2012 9:20pm
SteveMFr
Site Sponsor
New features added - link to thread with vid
http://www.fullfatrr.com/forum/post150469.html#150469
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #150470 9th Nov 2012 5:59pm
excellent. Thumbs Up ... - .- -.
Post #150477 9th Nov 2012 7:16pm
Steve, can you confirm which function denotes the hot monitoring of the side lights on the LCM module config.. ... - .- -.
Post #151329 15th Nov 2012 12:30pm
barracuda816
United Kingdom 2005 Range Rover Vogue SE Td6 Tonga Green
Hi, guys
Just bought one of these well regarded items, but im having trouble with the ccf part of it. I have a 2005 td6 facelift with the touchscreen. But when i select ccf it says ccf read fail. And im not able to save the config file either.
I have tried with the engine running ond just with the ignition on, it scans all 22 ecus ok. im not sure what is going wrong. Truth be told, this was the main reason i bought the item, so i could change the settings around.
Any help will be greatly appreciated.
Kind regards, Luke
Post #152388 20th Nov 2012 8:10pm
daveo
hi, when and got the car out of the garage today,when i started HDC inactive came up then had transmission fail come up and went in to safe mode,lots of revs but not going any where,a bit like driving with the brakes stuck on.. turned the car off and restarted all ok,no probs, been out all day not a thing all fine.
so i got out my IIDTool and this is what i found, just wondered if its a fault or a gremlin
TCM-TRANSMISSION.
1/1 3C-GEAR SWITCH FAULT:GENERAL FAULT
and this error in PATS-ANTITHEFT
1/1 3-KEY 0 - RAND.CODE TOLERANCE INCREASED
on the very odd accasion when i go to start i get a click and thats it,turn it of and try again it will start as normal
any info on the errors. V8 facelift Range Rover Autobiography 22" wheels.
Post #153262 24th Nov 2012 10:44pm
Lolo
Ireland 2011 Range Rover HSE TDV8 Santorini Black
Quick question, the error codes that come up on iid tool, are these Land Rovers codes or IID codes? I want to just give my Indy the code number so he can look up on his system.
Thanks
Post #154375 29th Nov 2012 4:35pm
@ daveo
Can answer the one about the key, straight from Patrick (as I had the same fault)
"We’ve seen many RR with this errors including our 2005, nothing to worry about."  .
Post #154378 29th Nov 2012 4:42pm
@lema, landrover codes..... Thumbs Up ... - .- -.
Post #154379 29th Nov 2012 4:45pm
Lolo
Thanks Thumbs Up
Post #154381 29th Nov 2012 5:02pm
