Home > Maintenance & Mods (L322) > 2012 Rear Led Taillight fitting
Page 1 of 4 1234>
MarkBrand
United Kingdom 2005 Range Rover Vogue Td6 Java Black
I am just about to start fitting a new set of 2012 led rear taillights to my 05 vogue, I saw an excellent guide somewhere in the past few weeks but can't find it again, so what problems are ahead of me, I have 2 ballist resistors at the ready for a "quick flashing indicators" problem should I need them, also going tomorrow to order 4 of the black mounting dock/plugs for the new mounting pins, I believe after a bit of digging that I might have fog light issues as well as dash warnings still to address, has anyone done this upgrade and easily got around all the issues if you could throw in your views/experiences I would much appreciate any tips before I remove my sc lights, as once they come out they are being sold and can't go back in and can't drive about with doggy rear light till I get stopped! Thanks in advance! Very Happy
Post #148902 30th Oct 2012 12:56am
is this what you're looking for [in the wiki]
http://www.fullfatrr.com/forum/topic9647.html
good luck with the install... ... - .- -.
Post #148909 30th Oct 2012 8:38am
MarkBrand
Thanks, I think that's it. I maybe getting it confused with a topic I saw which had part numbers and a bit more fitting details, but that could have been about the 2012 front end conversion.... Which is next on my to do list!
Post #148961 30th Oct 2012 7:19pm
you'll be busy for while then.. Laughing ... - .- -.
Post #148970 30th Oct 2012 8:01pm
Tuts
Where do you get the wiring correction/resistor boxes from? 2003 Vogue 4.4 V8 Java Black
Post #149000 30th Oct 2012 9:01pm
i think powerful uk sell them.. ... - .- -.
Post #149006 30th Oct 2012 9:10pm
MarkBrand
Yes, that's where I got mine.
Post #149009 30th Oct 2012 9:25pm
Stryke
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
They only sell them for the 02-05 (pre facelift cars)
Post #149019 30th Oct 2012 11:06pm
MarkBrand
I hope this isn't going to be a nightmare!
Post #149020 30th Oct 2012 11:13pm
+1 They dont work on a facelift/touch screen car...
Craig Mad
Post #149021 30th Oct 2012 11:20pm
MarkBrand
LoL and so the nightmare begins....
Post #149022 30th Oct 2012 11:26pm
dave699
England 2007 Range Rover Vogue SE TDV8 Stornoway Grey
Seen a 'box of tricks' advertised on Fleabay, which when I contacted seller, he assured me they were designed for the later cars. I think they were Ł125 for a pair but don't quote me.
Might be worth a search?
Had it, loved it!
2007 Vogue SE TDV8
Stornoway Grey / Ivory
Climatic Seats, RSE, AFS, Deployable steps, iPod kit.
Post #149028 31st Oct 2012 7:43am
dave699
http://www.ebay.co.uk/itm/Range-Rover-Rear...25763af102
Please make enquiries as to suitability for your FF. Thumbs Up
I haven't used these and have no other knowledge other than the enquiries I made when I was considering doing the upgrade.
Post some pics up when your done.
Had it, loved it!
2007 Vogue SE TDV8
Post #149029 31st Oct 2012 7:48am
bosch
United Kingdom 2018 Range Rover Autobiography SDV8 Corris Grey
These are the units i used on my car they are easy to fit using scotch locks and only took about 20 mins. they solved the fog light issue! Range Rover SDV8
Post #149991 6th Nov 2012 2:54pm
MarkBrand
So I went for a trail fit of the taillights tonight, plugged them in without the resistor just out of curiosity and everything works the way it should, the indicators flashed normal speed and nothing came up on the dash warning of errors or bulbs out, no disco lights on startup, break lights work.... only issue is the fog light is on all the time, any hints on how to fix this?? i need my rear fog lights and don't want to "just cut the wire to it" as i saw, as a fix somewhere!!
Post #150181 8th Nov 2012 1:46am
Page 1 of 4 1234>
