Home > Technical (L322) > Won't start - Immobiliser problems ?
Page 3 of 4 <1234>
Johnte
What's made you change your mind? Confused
Post #149395 1st Nov 2012 7:54pm
TugRR
Correct battery when replaced - six months ago ?
Just a thought now the cold is biting . . . .
Thumbs Up Where do you go after one of these . . . ?
Post #149396 1st Nov 2012 7:54pm
Johnte
Yes - one of the big Bosch ones from Euro Car Parts Thumbs Up
Post #149398 1st Nov 2012 8:09pm
Bob the B
United Kingdom 2004 Range Rover Vogue Td6 Santorini Black
Ive had the same problem a couple of times.
Put key in and turn to start, but nothing (cant remember hearing any noises).
The key will turn all the way without any problems/stopping/catching.
Try a couple of times then it will start.
I always take the key fully out of the ignition before trying again.
Post #149414 1st Nov 2012 11:30pm
ebajema
Maybe before you take the vaseline out and go to the stealers, take the immo ECU connector out and give it a good clean (contact cleaner) and see if that makes a difference. Maybe it is just a bad contact in there considering the age of the car. MY 2010 5.0 SC Galway green and sand interior!!
Post #149423 2nd Nov 2012 8:06am
Johnte
I'll buy some today, and give it a go Thumbs Up
Post #149438 2nd Nov 2012 9:32am
Lighty
Hi mate, can you describe exactly what happens when you turn the key? I presume you hear the click as the key goes in the slot, then do you have all the lights on the dash lit? DO they all stay lit or do the ones that should go out go out? Where are you based? Im in Manchester with All-Comms if needed? Just describe exactly what happens when you go through the start up sequence. If you want to talk on the phone mate drop me a PM
Cheers
Paul
Also be very careful when unplugging and re plugging ECU's whilst battery is still connected. Even when battery negative off the Immob ECU will draw a small current from the BCM that has battery in.
Post #149514 2nd Nov 2012 6:26pm
RF10
Switzerland 2006 Range Rover Vogue Td6 Zermatt Silver
I have just experienced similar. When turning the key all I got was a buzz/whirr/bleep sound and starter motor didn't even try to turn. Battery and starter motor all good.
Had to be towed to the dealer. It turned out it was the ignition switch in the console below the key.
Cost £170 + labor to replace.
Post #149596 3rd Nov 2012 12:08pm
ebajema
Didn't think of that but RF10 has a point there, could be the starter switch itself. Again use contact cleaner spray on it.
As for working on the ECU, correct they hold charge and it is best to take the battery poles of, hold the cable clamps together for at least 10 seconds to drain the charges (and clear fault codes) and then work on the ECU connector. MY 2010 5.0 SC Galway green and sand interior!!
Post #149597 3rd Nov 2012 12:17pm
mattyboy
United Kingdom 2003 Range Rover Vogue 4.4 V8 Oslo Blue
Have you tried it in Neutral rather than Park?
Post #149856 5th Nov 2012 2:16pm
Johnte
Got there in the end Thumbs Up Thumbs Up
This was the culprit Wink
Post #149992 6th Nov 2012 3:12pm
whats that then? ... - .- -.
Post #149993 6th Nov 2012 3:52pm
ebajema
Looks like a starter switch to me........... MY 2010 5.0 SC Galway green and sand interior!!
Post #150002 6th Nov 2012 5:16pm
Johnte
Ignition switch Thumbs Up
Post #150014 6th Nov 2012 6:23pm
trainmanone
England 2002 Range Rover HSE Td6 Oslo Blue
that was the same problem i had a few months back,gave it a good soak in contact cleaner,problem solved have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #150018 6th Nov 2012 6:32pm
Page 3 of 4 <1234>
