Home > Technical (L322) > Top Dash Speaker Grille Removal
mjdronfield
If you have managed to remove the speaker grille from the centre of the dash top, how the hell did you do it ?
RAVE says carefully release the clips............
But mine won't budge, and I've a feeling the corner of the grille is going to bend up and at least crack all the paint the grille is painted with.
Do you do the clips from underneath ? ie slide something flat inbetween the top of the dash and the bottom of the leather dash top, if you see what I mean.........pushing the clips from below.
It ain't gonna end well........... Rolling with laughter 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #149340 1st Nov 2012 4:15pm
you take the side vents off first then the dash..i'm sure there is a video on the powerful uk site [link in wiki] ... - .- -.
Post #149347 1st Nov 2012 5:14pm
The grill just pops out Thumbs Up
Post #149348 1st Nov 2012 5:23pm
Embarassed should have read the post properly... ... - .- -.
Post #149357 1st Nov 2012 5:48pm
mjdronfield
No worries Stan. I've watched the videos, and stared at RAVE, but they don't change what they say !
Mmmm it ain't just popin' out....... that's my issue I think.
I'm sort of protecting the dash top and trying to lever it up with a cake slice........ I knew it'd come in for something...... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #149371 1st Nov 2012 6:33pm
marcoos_1
Scotland 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Hmmm......I had mine of two nights ago and it did just pop up at the front edge. To be fair......it did take a bit of effort to get it to lift. Once the front edge is up you continue to lift it as it seems to sort of hinge along the back edge.....so don't try to lift it all the way round.
Post #149390 1st Nov 2012 8:10pm
SteveMFr
Site Sponsor
My grill was stuck down very solidly by ill placed sound deadening material from underneath. In retrospect, I think that the fact that the car stood in the hot sun for a while (and softened the glue) before I started to work on it prolly saved my grill from damage. Still, it was a fight. Neutral
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #149409 1st Nov 2012 11:30pm
fisha
i used a wide flat blade thing to lift it and spread the force. I found a thin screwdriver would cause it to bend a little ( too much force in a single place ) V8 or else ...
Post #149455 2nd Nov 2012 12:03pm
mjdronfield
Many thanks.
I'll have another prod at it over the weekend.
Cheers
Mark 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #149480 2nd Nov 2012 3:56pm
