![]() | Home > Technical (L322) > air suspension inactive message. |
Meerbusch Member Since: 16 May 2012 Location: Zürich (CH) + Düsseldorf (D) Posts: 325 ![]() ![]() ![]() |
... there is some help for your problem, look at the right side of ebay....
muffster Member Since: 03 Dec 2011 Location: Bradford Posts: 71 ![]() ![]() |
Hi again folks.
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3218 ![]() ![]() ![]() |
I'd just let Meerbusch do it and save the hassle if it was me (lazy and clumsy and not technical). It's only �100 or so. Not sure how much the kits are? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35633 ![]() ![]() |
there is a write up re stripping a compressor on the wiki, plus if you do a search you'll find loads of info .... ... - .- -.
Trist78 Member Since: 07 May 2011 Location: Worcester Posts: 78 ![]() ![]() |
It is easy to do ! If you have a poor memory like me just do what I did take photos of the compressor before you start. Cover all angles. Step by step take photos as you strip it down. So when you put it bact together you can use it for reference. |
