Home > Technical (L322) > air suspension inactive message.
muffster
2002 Range Rover Vogue Td6 Java Black
Well for anyone who may have the same issue, it turned out to be the compressor is knackered.
Had it plugged in to diagnostic machine and it confirmed it.
I just need to decide wether or not to rebuild it myself.
Post #146361 14th Oct 2012 4:29pm
Meerbusch
Germany 2017 Range Rover Vogue SDV8 Carpathian Grey
... there is some help for your problem, look at the right side of ebay....
regards, Uli L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #146515 15th Oct 2012 8:30pm
muffster
Hi again folks.
Could anyone in the know give me a quick rundown on rebuilding these compressors.
I intend to buy one of those kits off Ebay and Iv'e read a few threads, but can anyone tell me if it is that easy to do?
Are there any bits of the build where i'm likely to come unstuck.
I just don't want to get the thing in bits only to find i can't finish it for some reason.
Many thanks.
Post #148849 29th Oct 2012 5:20pm
Dolphinboy
I'd just let Meerbusch do it and save the hassle if it was me (lazy and clumsy and not technical). It's only £100 or so. Not sure how much the kits are?
Post #148857 29th Oct 2012 6:20pm
there is a write up re stripping a compressor on the wiki, plus if you do a search you'll find loads of info .... ... - .- -.
Post #148860 29th Oct 2012 6:38pm
Trist78
2004 Range Rover Vogue 4.4 V8 Java Black
muffster wrote:
Hi again folks.
Many thanks.
It is easy to do !
If you have a poor memory like me just do what I did take photos of the compressor before you start. Cover all angles.
Step by step take photos as you strip it down.
So when you put it bact together you can use it for reference.
Post #148898 29th Oct 2012 10:47pm
