Home > Technical (L322) > Here's a puzzler ??
steptoe
Here's a puzzler ??
2002 vogue, 4.4 V8.
Computer/sat nav screen was a bit darker than usual when starting up this morning. 5 minutes down the road it went blank and the radio stopped - it's now dead, except the land rover introduction logo flashes up now and again while driving along, it's pretty random in it's flashes of life, smooth road or bumps doesn't make any difference. Radio/CD is also dead, even the little orange on/off light is dead.
Now at the same time the instrument indicator lights also stopped working - the indicators all work, but no instrument indicator tell tale lights on the dash display. The instrument background lights are all ok, as is everything else.
When i say they all work, the left hand front indicator doesn't work, well it does if the lefthand indicator is on as you start/crank the engine, the moment the engine starts the left front stops . All other indicator lights work, including the side repeaters
Fuses all ok, even swopped them all around just to double check.
Anyone else had anything similar ?? Scratching my head and staring at it in confusion for the moment. Exclamation
Post #148330 26th Oct 2012 4:27pm
needs a new battery me thinks.... ... - .- -.
Post #148333 26th Oct 2012 4:31pm
andyboy
Wales 2004 Range Rover Vogue Td6 Java Black
Had some thing similar, looked in the back on the nearside,found water had got into my sat nav unit bm54 unit and lear unit. stripped it all out dried it,put it all back in after i found out where the water was coming in from, Stopped the leak with some 6 inch sticky lead flashing and gutter seal and bobs your auntys live in lover problem solved. hope this helps. gone fishin'
Post #148338 26th Oct 2012 4:43pm
mercs600
England 2002 Range Rover Vogue Td6 Java Black
Same as Andyboy - water in the connector pins - removed , dried and refitted with a small amount of silicone grease Wink
That was over a year ago and no further issues Thumbs Up
Post #148372 26th Oct 2012 6:03pm
SGW
United Kingdom 2009 Range Rover Autobiography 5.0 SC V8 Stornoway Grey
Had the same problem with my 02, water in the amp and bm 54 not so lucky as andyboy, had to replace the bm 54.
Stewart
Post #148722 28th Oct 2012 9:49pm
steptoe
No water anywhere. But would water in the satnav and amp unit effect the indicator lights on the instrument panel ?
Checked the battery, have all the volts but the amps seem to drop lower than they should when load testing the battery.
Post #148729 28th Oct 2012 11:45pm
