![]() | Home > Technical (L322) > Here's a puzzler ?? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35671 ![]() ![]() |
needs a new battery me thinks.... ... - .- -.
andyboy Member Since: 24 Aug 2010 Location: south wales Posts: 540 ![]() ![]() ![]() |
Had some thing similar, looked in the back on the nearside,found water had got into my sat nav unit bm54 unit and lear unit. stripped it all out dried it,put it all back in after i found out where the water was coming in from, Stopped the leak with some 6 inch sticky lead flashing and gutter seal and bobs your auntys live in lover problem solved. hope this helps. gone fishin' |
mercs600 Member Since: 19 Mar 2011 Location: North Yorkshire Posts: 425 ![]() ![]() ![]() |
Same as Andyboy - water in the connector pins - removed , dried and refitted with a small amount of silicone grease |
SGW Member Since: 09 Sep 2009 Location: Headcorn Kent UK Posts: 77 ![]() ![]() ![]() |
Had the same problem with my 02, water in the amp and bm 54 not so lucky as andyboy, had to replace the bm 54.
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 ![]() ![]() |
No water anywhere. But would water in the satnav and amp unit effect the indicator lights on the instrument panel ?
