![]() | Home > Wheels & Tyres > Rear Tyre wear |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35483 ![]() ![]() |
how have they worn?...on the edges, evenly straight across?
andrew-a Member Since: 07 Sep 2011 Location: Wirral Posts: 70 ![]() ![]() |
its unusual so try a different make, the kumhos look like they are to soft.. ... - .- -.
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
How heavy is your right foot? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 ![]() ![]() |
My rear tyres are wearing quicker on the outside edges - I've got Toyo's on and they have done about 10000 miles, still plenty tread on the middle but the outer edges are noticibly worn.
Probably under-inflated. ![]() As for the Kumhos, they are a soft compound but 4 or 5k miles sounds poor. I am at 30k on Pirelli Scorpion Zeros and they have about 3mm left all round. Michelin Diamaris have excellent wear rates but you pay a premium for them. I also don't like the harder compounds in winter so I tend to stick with the Scorpion M&S ones. |
Bushes and setup........ Should get between 25K and 40K out of tyres depending on tyre and your driving style... I have a 19yr old customer who drives his TD6 like he stole it everywhere, and still gets 20K plus out of his tyres... My last set of Toyo's i removed with 3.5mm of tread left after covering 34,000 miles and only removed them as they were perishing...
Thanks for the replies - I know that the alignment is OK and tyre pressures are also OK so I'm guessing that the rear bushes may have some wear in them.
Glideman Member Since: 11 Sep 2011 Location: Stood next to a broken down Range Rover in Darwen Posts: 112 ![]() ![]() ![]() |
I have the same car as you and run Michelins, they only last me 10,00 miles. Had all the bushes done trying to find a bloody knock so it's not that & it's had all the wheels aligned. Range Rover 4.4 V8 Vogue |
MPx Member Since: 29 Jul 2011 Location: South Somerset Posts: 601 ![]() ![]() ![]() |
If its just rears, it could be related to towing? I've had a noticeable difference (increase) in wear rate when I've had periods with lots of towing....but went over 30k on Rodians of all things with just the car. Mike - MPx
I have the same problem, wear on outer edges that is. It's not tyres as had same issue with Nexen Roadians, Grabber ATs and Pirelli Scorpions. Must be bushes/alignment. This is on my to do list |
Interesting to hear that others have the same issue with outside wear on the rear tyres........as I said, mine have done about 10k and the outer edges are almost shot - near side slightly worse than the off side which you would expect from roundabouts etc.
shalz Member Since: 28 Jan 2013 Location: where FFRRs roam free...! Posts: 507 ![]() ![]() ![]() |
I've just gone to view a 22,000 mile car which showed a lot of wear on the outer edge of the front tires, lot more on the nearside and generally more than the centre parts. The car was also pulling slightly to the left when I drove it. The dealer is prepping the car now and I'll ask them to take a look at both alignment and front bushes. Will let you know if they report anything back.
dave699 Member Since: 03 Apr 2012 Location: Redcar Posts: 457 ![]() ![]() ![]() |
When I got my car the outer edges of the Toyo's were showing a lot more wear than the, centre / inner edges
