Home > Wheels & Tyres > Rear Tyre wear
666tur
United Kingdom 2012 Range Rover Vogue SE TDV8 Zambezi Silver
I am running scorpion ATs, the fronts are wearing on the inner edges and the rears are wearing on the outsides, particularly the off side which could mean a worn bush. The centres have loads of tread after 20k miles. Is there much adjustment that can be made to the rear? 2012 4.4TDV8 VSE
2004 TD6 132k miles- SOLD
1995 Land Rover Defender 110 Tithonus Ex Military
1995 Land Rover Discovery 3.9i V8 manual
Post #251795 31st Mar 2014 7:41pm
Bofa Bill
Scotland 2003 Range Rover SE Td6 Epsom Green
Wear on both outside edges used to mean underinflated tyres
Have ye checked PSI and out of intrest, what pressure are you running?
HTH's
Bill Made in Scotland frae 'Girders'
Post #251821 31st Mar 2014 9:06pm
666tur
One side is worse than the other, have been setting the psi at what ever it's says in manual and check them cold. Can't remember what. I wondered if it was a characteristic of the AT tyres, my previous tyres have worn surprisingly evenly. Will check again, perhaps experiment with increasing pressure. 2012 4.4TDV8 VSE
Post #251822 31st Mar 2014 9:11pm
Bofa Bill
I run mine @ 36psi
Most of my drives are M/W so I can put up with the extra 'bumps' while in town. Made in Scotland frae 'Girders'
Post #251827 31st Mar 2014 9:28pm
