Home > In Car Electronics (L322) > radio problem any ideas
trainmanone
England 2002 Range Rover HSE Td6 Oslo Blue
got hse with sat nav on a 52 plate radio is fine when key in pos 1 or 2 ,when you start the car ie pos 3 then back to 2 after five to seven seconds sound goes off,turn car off back to pos one and two its ok till you start up again then dose the same again only happens every so oftern but realy anoying can be off for ten mins then come on for a couple then off again
hope some one can point me in correct direction hve tried contact cleaner on the multi plugs in the boot area
regards
pete have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #134065 2nd Aug 2012 10:47am
Baris
Sounds like a Bm54 problem.Let me know of you want it repaired.
Post #147234 20th Oct 2012 4:55pm
trainmanone
its fine now was dirty contacts on ignition switch and unit in boot
thanks anyway
Post #147236 20th Oct 2012 5:06pm
Baris
Good stuff Smile
Post #147237 20th Oct 2012 5:21pm
