![]() | Home > Maintenance & Mods (L322) > Dropping the fuel tank on a TD6 |
Has anyone done this??
Well to add to this on startup this morning went to pop the bonnet and SNAP,
So are they going to drop the tank for you? |
Hope so John,
Nothing worse than scrambling around on your back trying to undo rusted nuts and bolts.
i have thought about that but there aren't many places that offer it |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
Could you make yourself some solid wood ramps? Might give you enough space to attemp the prop shaft. Would be safer than the coke can ramps you can get from halfords. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Looked at it with the car in extended mode on my dads ramps(older but much stronger than the halfrauds coke can ones) but it really does need to be up in the air to be done right as its just way to awkward otherwise.
Alternative method to ramps |
Well I'm screwed as they couldn't find what was wrong at all. Nearest good garage can't get it in till Tuesday and land ranger in Stockport can't get it in for a few weeks even |
Give these guys a call. http://a1-landrover-specialists.co.uk/ they sorted mine when the selling dealer were scratching their heads. There in Bury so not a million miles from you. There is also deeside 4x4 in deeside and Ian Barkley in Birkenhead. All good garages but the last 2 might be to far for you. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Cheers rob ill give them a bell in a few minutes and see what they can do |
Why don't you do it the African way, flip the car on its side if you want to work on the bottom ??? Also, much easier to drain the tank |
Yeah i dont think i can flip it on the side without additional cost.... |
