Home > Maintenance & Mods (L322) > Dropping the fuel tank on a TD6
Has anyone done this??
The tank i have is half full as well which does not help in the slightest but from what i can see there is no other way to get the sender or feed/return fuel hose/lines and their unions Sad
What a fraggle rocking mess!
My thinking is that I need to drop the exhaust at the back and the front then drop the tank shield then I can finally get access to the tank strap which is a bolt or two front and back. with the tank adequately supported and filler neck disconnected I can then begin to somehow drop about 60kg weight to the floor.
I have managed to get the car running again so I may buy a few metres of fuel hose from halfrauds and then use the lift pump to try and drain as much off the tank as I can as pump a few litres a minute judging by the rate it sucked the stuff up earlier and that will help a lot Smile
So has anyone done this??
CTC maybe?? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #145813 10th Oct 2012 3:23pm
Well to add to this on startup this morning went to pop the bonnet and SNAP,
cable went Sad
So its in the garage now fingers crossed they can get it today as i really need the car back today as i need it for work Sad FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #145939 11th Oct 2012 9:47am
So are they going to drop the tank for you?
Post #145943 11th Oct 2012 10:09am
ebajema
I have got a L322 PDF Workshop manual for your MY range that I can flick to you if you give me an email address. As far as I can see the tank sits across the drive shaft to that needs to be removed as well.
It also looks that the filler hose sits at the bottom of the tank so that would be a good point to drain the fuel, take the filler hose of an have a big bucket or tray sitting there to catch it in batches.
Next week I have the mechanics here open up my tank (the two covers inside the car) to clean it out as I am afraid it is full of crap causing all kinds of issues. MY 2010 5.0 SC Galway green and sand interior!!
Post #145945 11th Oct 2012 10:17am
Hope so John,
Thanks for the offer Eb,
Getting to the two covers wasn't so bad. The tank was super clean inside but the fuel was mucky(some old engine oil was in my transfer container) but not gloopy or dirty perse other than that and i know the engine can run on a very tiny amount of engine oil and we are talking only about 100ml but it spreads quick in the BioD.
I'm hoping they can get it sorted.
The big part for me was the prop shaft, I just don't have the ability to get it off Sad
If I had a garage like yours John I could have stood a chance as i dont mind the work but on your back with only about 1-1.5' of space is too hard Sad
Biggest problem is finding a garage round here that has a lift wide enough and strong enough to lift the FFRR Evil or Very Mad FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #145950 11th Oct 2012 10:42am
Nothing worse than scrambling around on your back trying to undo rusted nuts and bolts.
Might start renting out some ramp space Whistle
Post #145955 11th Oct 2012 10:54am
i have thought about that but there aren't many places that offer it Sad FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #145966 11th Oct 2012 11:36am
Could you make yourself some solid wood ramps? Might give you enough space to attemp the prop shaft. Would be safer than the coke can ramps you can get from halfords. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #145972 11th Oct 2012 12:11pm
Looked at it with the car in extended mode on my dads ramps(older but much stronger than the halfrauds coke can ones) but it really does need to be up in the air to be done right as its just way to awkward otherwise.
It is do-able dont get me wrong but on the wrong side of risky for me.. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #145973 11th Oct 2012 12:16pm
Alternative method to ramps Laughing Laughing
Post #145987 11th Oct 2012 1:11pm
Well I'm screwed as they couldn't find what was wrong at all. Nearest good garage can't get it in till Tuesday and land ranger in Stockport can't get it in for a few weeks even Big Cry
Anyone know a good landy or diesel specialist in Manchester or Warrington?? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #146015 11th Oct 2012 5:16pm
Give these guys a call. http://a1-landrover-specialists.co.uk/ they sorted mine when the selling dealer were scratching their heads. There in Bury so not a million miles from you. There is also deeside 4x4 in deeside and Ian Barkley in Birkenhead. All good garages but the last 2 might be to far for you. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #146030 11th Oct 2012 7:42pm
Cheers rob ill give them a bell in a few minutes and see what they can do Smile
If worst comes to worst I can get it flat bedded over there as part of my recovery thing.
In the meantime I'm £300 banger hunting to get me by for a month or two and transfer insurance to it and sorn rover in meantime if it takes to long.
Looking at a nice wee diesel with only 270,000 on its clock and a few months t&t! A another is a xantia with unknown mileage and another is a black cab with unknown mileage but could be a laugh!! Wear 2 guvna! Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #146056 12th Oct 2012 8:15am
ebajema
Why don't you do it the African way, flip the car on its side if you want to work on the bottom ??? Also, much easier to drain the tank Smile MY 2010 5.0 SC Galway green and sand interior!!
Post #146075 12th Oct 2012 9:12am
Yeah i dont think i can flip it on the side without additional cost.... Wink
I even tried williams yesterday in manchester and they promised a callback yesterday, just rang me back now whilst in a meeting... FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #146078 12th Oct 2012 9:31am
