![]() | Home > Technical (L322) > Steering squeak when turning UPDATED |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 ![]() ![]() |
Is it just one short squeak or a continuous noise until the steering wheel is straight again? Previously..
Thelord67 Member Since: 19 May 2012 Location: Stockport Posts: 27 ![]() ![]() ![]() |
It's one squeak, like a rusty hinge on a door Range rover tdv8 56. Vogue
Bottom balljoint is a likely suspect |
That doesn't sound too bad and ties in with fact it is pulling left ever o slightly.
If you are not sure on how to check it, Ask your garage to have a look to confirm, it should take all of 1 minute ! Then phone warranty direct and ask. |
Garage have just phoned and its both ball joints. Specifically both front lower arms and both rear arm bushes.
I am guessing a good £250 's worth of that is labour and profit |
Wow what a difference, car drives in a straight line, no vibration at all through the wheel. There was before. All squeaks, bangs and knocks have gone.
