Home > Maintenance & Mods (L322) > Wiring up Rear Reflectors as Rear DRL's |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
As the title says. There seems to be enough space to get some strip LED's in there, just a case of running the wiring back to the front of the car to link up with the fronts.
8th Oct 2012 8:35am |
Hmmm, thinking about this way of doing it as my DRL's at the front (in the fog lights) are linked into the headlight live feed, not using a navcoder/RAC/IID Tool fix.
8th Oct 2012 11:52am |
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1665 |
Er, use sidelights? |
8th Oct 2012 11:53am |
@ Martin
8th Oct 2012 11:55am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3978 |
You could take the wiring over the roof but I think it would be better underneath. Plenty of room under there. I would sleeve the cable with 10mm convoluted sleeving to give a bit of protection, also looks more professional.
8th Oct 2012 12:10pm |
Alternatively could fit a second DRL unit just for the rear. Is there an ignition live feed at the tail lights that I can then route cable from to the bumper? .
8th Oct 2012 12:58pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35377 |
i just went out to have a look at mine and tbh it would look pants tim.. ... - .- -.
8th Oct 2012 1:04pm |
@Joe
8th Oct 2012 2:24pm |
wouldn't doing that make the 'new' rear drls stay on all the time , even at night.. ... - .- -.
8th Oct 2012 2:33pm |
Yes, can't see the point in turning them off/dim on the rear, I doubt you could get the reflectors bright enough to cause a problem at night. Just use them as supplementary rear lights. |
8th Oct 2012 3:20pm |
Turbo Tony Member Since: 06 Apr 2010 Location: London Posts: 243 |
How about using the red/amber side markers, like in the US market models? Researching my first Range Rover purchase |
8th Oct 2012 5:07pm |
@ stan
8th Oct 2012 7:52pm |
..and you are one of the few peeps on the forum that would do a good job... watching the thread with interest tim... ... - .- -. Y. O. L. O. . |
8th Oct 2012 7:55pm |
8th Oct 2012 8:08pm |
