Home > Maintenance & Mods (L322) > Wiring up Rear Reflectors as Rear DRL's
Page 1 of 4 1234>
As the title says. There seems to be enough space to get some strip LED's in there, just a case of running the wiring back to the front of the car to link up with the fronts.
[EDIT] topic heading change as this has become a reality Very Happy .
Post #145268 8th Oct 2012 8:35am
Thought about it as you describe.
Someone on Disco 3 did it but the results were pretty feeble and he never persued it further.
Presumably you would need very bright leds.
Probably easier to fit leds into the rear tail lights in addition to bulbs or even arrange for the tail lights to be on when drl's are lit.
Post #145277 8th Oct 2012 9:05am
Hmmm, thinking about this way of doing it as my DRL's at the front (in the fog lights) are linked into the headlight live feed, not using a navcoder/RAC/IID Tool fix.
My nirvana would be DRLs on front and back along with internal dash panel lights (in the binnacle / can hardly see the dash even in broad daylight, not like my Audi which has illumination/luminosity all the time.
How to get wiring from back to front - what's the best route externally ? .
Post #145303 8th Oct 2012 11:52am
Martin
Site Admin
Er, use sidelights? Confused Wink
Post #145304 8th Oct 2012 11:53am
@ Martin
I have a secret desire for a car that is really a Christmas tree Rolling Eyes .
Post #145305 8th Oct 2012 11:55am
You could take the wiring over the roof Smile but I think it would be better underneath. Plenty of room under there. I would sleeve the cable with 10mm convoluted sleeving to give a bit of protection, also looks more professional.
Be interested to know what you do for the rear lights.
Post #145308 8th Oct 2012 12:10pm
Alternatively could fit a second DRL unit just for the rear. Is there an ignition live feed at the tail lights that I can then route cable from to the bumper? .
Post #145312 8th Oct 2012 12:58pm
i just went out to have a look at mine and tbh it would look pants tim.. ... - .- -.
Post #145316 8th Oct 2012 1:04pm
@Joe
Fuse 8 on the rear fuse board appears to be ignition controlled and doesn't serve anything. You could use a piggy-back fuse holder in it and run direct to your lights, no need for a Drl relay.
Post #145330 8th Oct 2012 2:24pm
wouldn't doing that make the 'new' rear drls stay on all the time , even at night.. ... - .- -.
Post #145331 8th Oct 2012 2:33pm
Yes, can't see the point in turning them off/dim on the rear, I doubt you could get the reflectors bright enough to cause a problem at night. Just use them as supplementary rear lights.
Post #145345 8th Oct 2012 3:20pm
Turbo Tony
How about using the red/amber side markers, like in the US market models? Researching my first Range Rover purchase
Post #145361 8th Oct 2012 5:07pm
@ stan
Would look pants only if not done right Thumbs Up
@ nicey
Thanks for the tip about fuse 8.
Would use a second DRL dongle thingy, just for the rears, which might allow dimming when lights come on. I'll have to have a think about this as the benefit of linking to the front DRL's is that they are wired into the headlights so when headlights come on they dim by @ 50% (this is what my front DRL's do now).
Just like the idea of being automatically lit up at both ends on start up (there is probably a cue there for Joker or 47p2!!), using only low powered LEDs, instead of having to switch on the sidelights. .
Post #145400 8th Oct 2012 7:52pm
Joe90 wrote:
@ stan
..and you are one of the few peeps on the forum that would do a good job... Wink
watching the thread with interest tim... ... - .- -.
Post #145402 8th Oct 2012 7:55pm
Thumbs Up .
Post #145409 8th Oct 2012 8:08pm
Page 1 of 4 1234>
