![]() | Home > Technical (L322) > How to find an Airleak on the TD6 fuel lines :( |
This is the first time this has happened and i was a little worried....
Might be the secondary fuel pump starting to play up |
Ah the in-tank one John??
No the one just in front of the rear near side wheel. there are a couple of small bolts hold a cover plate, remove them for access. If the engine fails to start again give the pump a light tap with a spanner/hammer to try and get it running
Cheers John.
Added the link (see above above), the brushes and commutator wear out causing the failure |
Thanks John just read it now |
Bit pricey but i guess at about �15 a year not too bad! FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
I think you can buy copy pumps for around �45 from the bay...pays your money and takes your chances |
Exactly John, Do i want to take that chance part way through a raging river.... Me thinks not.
Do you know the name of that type of clamp, I have pliers for the CLIC-R clamps but they don't work on the RR clamps
It is in the grey matter but it escapes me at the moment.
bergxu Member Since: 18 Jan 2012 Location: Cincinnati Posts: 61 ![]() ![]() ![]() |
Those clamps are called cobra clamps.
Trip home report...
