Home > Technical (L322) > How to find an Airleak on the TD6 fuel lines :(
Page 3 of 3 <123
RCusden
Wales
The problem I had was the high Pressure pipe between the high pressure pump on the front of the engine and the fuel rail. It would cause the fuel to rain back to the tank when Parked but would leak when running can you see or smell any fuel leaking.
Roger
Post #145667 9th Oct 2012 7:55pm
No fuel leaking from what I can see as it just seems to happen under load as it sat and idled for ages earlier after I swapped the pump out Sad FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #145670 9th Oct 2012 7:59pm
Well a quick bit of testing shows that the air is being pulled in by the pump.
I flipped the pump round and gave it a litre or two of juice to feed its thirst in the hope that it would show a leak but no luck,
I'm starting to think the in tank pickup/pump has come adrift and is causing the issue but ive never seen one or heard of this before so am totally stumped now.
Also to remove the tank it looks like the exhaust has to come off and the tank dropped which being half full is about 50kg+ in weight.... Not so bad if the car is up in the air but for me its on the drive! THe flip side is taking it off it can be drained into some containers i have so refitings isnt too bad!!
Anyone done this before? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #145782 10th Oct 2012 10:24am
trainmanone
England 2002 Range Rover HSE Td6 Oslo Blue
what was the outcome?? have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #254228 13th Apr 2014 3:00pm
Page 3 of 3 <123
