Home > Maintenance & Mods (L322) > Mr Tee's Java swirl mark removal |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2655 |
Now that the car is running great, it was time to take care of the paintwork. I'd tried to rid the car of swirl marks before by hand, using Farecla products but the outcome was always the same, it looked great from a distance, but utter pish up close. So I was in Ellon on business and on my way home nipped into Kintore to these guys:
24th Sep 2012 8:21pm |
Looks fantastic. The one thing RR can do is good paint that even when abused comes up a treat with some TLC |
24th Sep 2012 8:58pm |
Aye, I'd been kidding myself on that it looked ok, but when in direct sunlight it looked awful. Only things left to do are the front bumper & I'll do the edges of the roof next weekend weather permitting. Well worth the effort, much cheaper than a respray! Had my mate ask me if I could do his jag, wonder how much I could charge |
24th Sep 2012 9:05pm |
If the paint on the bumpers and the plastic on the bottom of the doors is all original you will find it much more difficult to remove marks. Just be careful you don't cause any heat damage trying |
24th Sep 2012 9:32pm |
Think it is original paint, I had a wee mishap on the rear bumper, nothing major though, so will only use the less aggressive compound on the front, thanks for that, wish I'd know before |
24th Sep 2012 9:54pm |
It needs to be an aggressive compound to cut through the swirls, but you have to keep moving the pad to stop the heat building up. Do an area until it starts heating up, move along and do another area, move along and do another area then go back to the beginning and start all over again. It can take a while |
24th Sep 2012 10:03pm |
Thanks for the tip, it's certainly been an eye opener so far. Planning to,keep the car now that the mechanical side is ok now. Will try & get some better photos if the weather clears later in the week , very happy with the results so far. Now do I go the whole hog & do the entire roof? Christ ,I would need staging boards |
24th Sep 2012 10:13pm |
Allan Member Since: 15 Aug 2012 Location: Yorkshire Posts: 46 |
You missed a bit...
24th Sep 2012 10:15pm |
The roof isn't too bad to do, you don't need to be too fussy with it as nobody sees the swirls unless they are 8' tall, but you should give it a quick blast over and spend a little time on the paintwork just above the windows |
24th Sep 2012 10:21pm |
Turbo Tony Member Since: 06 Apr 2010 Location: London Posts: 243 |
Now this is my kind of thread. Excellent work - well worth the effort.
24th Sep 2012 10:26pm |
Aye it takes a wee while to cut through the swirls. Was a wee bit cautious as I didn't want to blast through the clear coat! |
24th Sep 2012 10:30pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
Nice work Mr Tee - got me enthused to use all the gear I bought to do the same! .
24th Sep 2012 11:09pm |
You're pretty safe with a DA polisher - I'm sure you already know they're designed to stop rotating if too much pressure is applied, so they don't build up as much heat as a rotary can.
24th Sep 2012 11:49pm |
RCusden Member Since: 12 May 2012 Location: NarberthPembrokeshire Posts: 186 |
Wow |
25th Sep 2012 5:48am |
