Home > Maintenance & Mods (L322) > Mr Tee's Java swirl mark removal
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
Now that the car is running great, it was time to take care of the paintwork. I'd tried to rid the car of swirl marks before by hand, using Farecla products but the outcome was always the same, it looked great from a distance, but utter pish up close. So I was in Ellon on business and on my way home nipped into Kintore to these guys:
http://www.polishedbliss.co.uk/ and I bought the kit to rectify my shoddy paintwork, see here:
http://www.polishedbliss.co.uk/acatalog/pb...-cat1.html plus the Kestrel DAS 6 polisher, and snow foam + lance.
I started early Saturday morning, finishing around 7pm, and again on Sunday, getting it finished by 3.30pm. Once you see the before pictures, you'll understand why it took so damn long!
Before: every panel had the same level of marking, very, very poor but what can you expect on a car over 10 years old!
not too bad from a disctance Rolling with laughter
Up close on the wing:
Doors:
The start, a nice foamy wash.
Then wash, dry, clay and on with the masking tape:
Then after around 10 hours with the buffer & the coarse compound, finished with Auto Finesse tough coat:
Apologies for no extreme close up photos as per detailing forums, but I have no clue how to work my DSLR on manual setting!
I now understand why detailing companies charge healthy sums for paint correction... thanks for looking :thumbsup:
Post #142825 24th Sep 2012 8:21pm
Very impressive! Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #142826 24th Sep 2012 8:38pm
Looks fantastic. The one thing RR can do is good paint that even when abused comes up a treat with some TLC
Post #142827 24th Sep 2012 8:58pm
Mr Tee
Aye, I'd been kidding myself on that it looked ok, but when in direct sunlight it looked awful. Only things left to do are the front bumper & I'll do the edges of the roof next weekend weather permitting. Well worth the effort, much cheaper than a respray! Had my mate ask me if I could do his jag, wonder how much I could charge Whistle
Post #142828 24th Sep 2012 9:05pm
If the paint on the bumpers and the plastic on the bottom of the doors is all original you will find it much more difficult to remove marks. Just be careful you don't cause any heat damage trying
Post #142833 24th Sep 2012 9:32pm
Mr Tee
Think it is original paint, I had a wee mishap on the rear bumper, nothing major though, so will only use the less aggressive compound on the front, thanks for that, wish I'd know before Mr. Green
Post #142840 24th Sep 2012 9:54pm
It needs to be an aggressive compound to cut through the swirls, but you have to keep moving the pad to stop the heat building up. Do an area until it starts heating up, move along and do another area, move along and do another area then go back to the beginning and start all over again. It can take a while
Post #142846 24th Sep 2012 10:03pm
Mr Tee
Thanks for the tip, it's certainly been an eye opener so far. Planning to,keep the car now that the mechanical side is ok now. Will try & get some better photos if the weather clears later in the week , very happy with the results so far. Now do I go the whole hog & do the entire roof? Christ ,I would need staging boards Rolling with laughter
Post #142847 24th Sep 2012 10:13pm
Allan
You missed a bit...
Joking..
Very nice work, well worth the effort. Thumbs Up
Post #142848 24th Sep 2012 10:15pm
The roof isn't too bad to do, you don't need to be too fussy with it as nobody sees the swirls unless they are 8' tall, but you should give it a quick blast over and spend a little time on the paintwork just above the windows
Post #142850 24th Sep 2012 10:21pm
Turbo Tony
Now this is my kind of thread. Excellent work - well worth the effort.
Thumbs Up Researching my first Range Rover purchase
Post #142852 24th Sep 2012 10:26pm
Mr Tee
Aye it takes a wee while to cut through the swirls. Was a wee bit cautious as I didn't want to blast through the clear coat!
Post #142853 24th Sep 2012 10:30pm
Nice work Mr Tee - got me enthused to use all the gear I bought to do the same! .
Post #142857 24th Sep 2012 11:09pm
Turbo Tony
You're pretty safe with a DA polisher - I'm sure you already know they're designed to stop rotating if too much pressure is applied, so they don't build up as much heat as a rotary can.
It's a good idea to draw marks on the back of the backing plate, so you can easily see if the pad is still rotating. That way, it's easy to see if/when you need to use less pressure. There's loads of videos on Youtube for anyone else who's a little nervous about trying polishing for the first time.
Mind you, you seem to have got the hang of it pretty well. Your car looks stunning. Researching my first Range Rover purchase
Post #142858 24th Sep 2012 11:49pm
RCusden
Wales
Wow Bow down
Post #142861 25th Sep 2012 5:48am
