Home > In Car Electronics (L322) > analgue tv on touch screen
Page 2 of 3 <123>
The second item from my second link I found priced at @ $1200 !!!
Also seems we are getting into "spy" territory.
Not much about in the UK due to the legalities of transmitting over UHF .
Post #141540 17th Sep 2012 11:37am
Andy3681
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
Thats the most system stan which as you point out correctly we cant touch.
I was going to send you the TV page from Rave but have just found out my new PC with windows 7 dont like it Big Cry
If I am misunderstanding your replys please forgive me but all I want to do is connect a small free view box between the cars aerials and the receiver just like you would at home but I am defeated by there being two aerials with two inputs to the receiver. so simple but so awkward to do with not knowing enough about the TV. I thought about if there was an av in on the reciever but then you get the sound problem like has already been mentioned.
And I dont know if the aerials will work without being powered up???? Mine was a blue one! Smile
Post #141541 17th Sep 2012 11:49am
i can see they way you are thinking andy...a normal freeview box will pick up the digital signal , convert it to analogue and then push it out either via a modulated signal or a scart signal to the tv...
as i see it the stumbling block with the fullfat is where the analogue or hybrid tuner is, both input and output to those bits of hardwhere is MOST...[i think] ... - .- -.
Post #141563 17th Sep 2012 1:37pm
Andy3681
That would stay the same.
You would just connect the Freeview box and let the car tuner tune to it ( I think its usually channel 38 ish) so the car would have One channel.
You would then change channel etc with the freeview box's remote not ideal but would work. Its just connecting the aerials thats my issue I would do it but I dont know enough about them. If yo go to the aerial connection on the car receiver and unplug the aerials you can read a voltage ( not sure what it was as did it last year ) This I think powers the amplifiers on the aerials. Mine was a blue one! Smile
Post #141565 17th Sep 2012 1:46pm
I also found a dvb modulator that converts AV output to RF input, so it is just the piping of the RF signal into the TV that seems to be the issue. .
Post #141571 17th Sep 2012 2:04pm
the rf signal is the problem as there isnt a way of introducing it into the system..a rgb signal straight to the monitor would work but again no sound..
andy, i can see that a voltage from the aerial amps isnt gonna go down well in the freeview box.. ... - .- -.
Post #141579 17th Sep 2012 2:36pm
clemenz
Austria 2006 Range Rover Vogue Td6 Zermatt Silver
excuse me to bring up this old topic but i got news on that stuff Very Happy
proud owner since august i was wondering if i can get any video into the system
without spending hundreds of pounds. as the topic starter said "for that i can get a 40" for the toilet" Very Happy
i found a relative cheap way to bring an rf signal onto our analogue tuners and ordered it
yesterday in japan, should be here by the end of the week. if it works, i post pictures Cool
that is this lovely device which brings analog ntsc video to our FFRR (only mono, for me its ok)
price is around 8000yen with shipping and they are very helpful. had problems to order on their japanese site and
they send me an pdf where to enter what to order, that is customer care Thumbs Up
http://eleshop.jp/shop/g/g402107/ (i used chrome auto translation for that)
the plan is to hook up a dvb-t2 freeview box on that device in the trunk!
Post #318435 17th Mar 2015 11:52am
J90
France 2006 Range Rover Vogue Td6 Java Black
Thanks Clemenz. Looking forward to the result. Travelling around in circles again.
Post #318454 17th Mar 2015 1:54pm
tanertimur
England 2005 Range Rover Vogue Td6 Java Black
I have a gvif interface which i bought to fit a reverse camera to and on the interface it allows me to connect 3 A/V devices. I bought a cheap DVB-T from the bay and fitted this to it. I did have to buy two window aerials for the DVB-T one on each side of the rear screen to get good signal (which i do) and works perfect.
As mine is a MOST system i also had difficulties with the audio, unless you have RSE with a AUX input to connect the DVB-T audio to like me you may have to use a FM transmitter and have the audio played through your radio.
which does the job.
I know you guys were looking for a cheap option and ideally to use the analogue tuner already fitted but i thought i would just detail what i have used.
it would be interesting if someone can get the analogue system incorporated with a digital freeview. Range rover td6 54 reg touch screen
Post #318962 21st Mar 2015 3:03pm
clemenz
thanks for your information. why i ordered this transmitter is that i wanted nothing added to the existing system. the signal should be from "outside" the system. nothing was in my mail on friday so i am hoping to get the transmitter by monday... i will post pictures etc. if it works Thumbs Up
Post #318974 21st Mar 2015 6:19pm
tanertimur
Keeps us updated. Im sure alot of people would be intrested if this works. Range rover td6 54 reg touch screen
Post #319084 22nd Mar 2015 5:55pm
87RJD
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Hi all
Am I missing something here, mine and my brothers 07 cars TV's work, with a reasonable chanel choice, does this mean someone has updated the TV receivers in the cars already? I thought all 07 cars, or newer one's that the TV's would work. Something to watch out for if this isn't the case, if I buy a newer one. SC 4.2, 2012 face lifted, 25K miles, 1 previous owner
Triumph TR6 1973
Triumph Bonneville 1970
Previous:
2002 TD6
Merc SL500
Escort RS Cosworth
RR 3.9 Vogue
4.2 E type Jag replica (challenger)
Escort RS2000 (many)
Escort RS 1600 Turbo
Post #319101 22nd Mar 2015 7:31pm
clemenz
the info i have is that:
If you have the Terrain Response/updated interior the car should have Hybrid Tuner. Till MY06 with facelift the old one was fitted.
Post #319105 22nd Mar 2015 8:25pm
87RJD
OK, thanks for the update SC 4.2, 2012 face lifted, 25K miles, 1 previous owner
Triumph TR6 1973
Previous:
2002 TD6
Merc SL500
Escort RS Cosworth
RR 3.9 Vogue
Post #319120 22nd Mar 2015 9:26pm
clemenz
Device arrived today, had a quick hookup and tried it. picture is ok, sound a bit noise und not as loud as radio.
after some time my tuner made some weird things:
black bands on top of picture even when there was no signal. was not able to get a picture.
next try, sound was there, tuner had no picture but when i switch between radio and tv i get picture for a sec, than its black.
looks like there is something wrong with my tuner?
have to try it next week with my fathers one...
Post #319398 24th Mar 2015 11:11am
Page 2 of 3 <123>
