Home > In Car Electronics (L322) > analgue tv on touch screen
Page 3 of 3 <123
clemenz
Austria 2006 Range Rover Vogue Td6 Zermatt Silver
as i have problems with the signal strength,
does anyone know what part number the antenna is or what type
of plug? i'm thinking about to give the signal direct to the tuner via cable!
Post #333993 22nd Jun 2015 10:59pm
clemenz
after some months i'm now back on the project...
i tried to have a direct connection between the interface and the tuner,
i removed one antenna und put the cable straight into the connector.
"clear" analoge picture...
now i will find me a garage that installs me the stuff properly Smile
so the plan is to have a cheap dvb-t tuner hocked up to the original antennas..
controlled via a ir remote that puts analogue video to the rf interface, which is connected to
the old tuner that is set on one channel only, i hope it works Smile
again some pics...
Post #404319 10th Sep 2016 12:53pm
clemenz
A quick questions, i hope someone can help me?
Should i grab the power from the existing cable that goes into
the factory tuner? Thanks
Post #406822 28th Sep 2016 5:34pm
Weegie
Not clear from your photos but, as I understand it, you are inserting the new tuner between the aerial and the existing tv tuner. Is that correct?
If so how are you connecting the new tuner to the existing one.
I may have misunderstood. John
GAP iiD BT-Sold
Post #406838 28th Sep 2016 6:57pm
clemenz
I have a RF modulator for car purposes that gives me a simple analogue tv output to the existing tuner.
The existing tuner remains on one channel only and gets the signal from the modulator.
The new tuner will give its output to the new modulator.
the thing is, i need a power source for the 2 devices that is switched with the old tuner, so if the existing one is on,
the new tuner and the modulator should be activated. so i'm thinking about to get the 12v power from the
existing cable that goes into the old tune, so to divert the cable and use it.
is this possible?
Post #406845 28th Sep 2016 7:36pm
miggit
I would use the power supply to the old tuner to switch a relay and take the power feed from the other side of the boot were the second fuse box is Thumbs Up
So your digital tuner outputs an analogue RF signal ? as opposed to tapping a video feed in to the tuner, assuming that there is such a thing... there are 3 on the BMW style tuners Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #406892 29th Sep 2016 12:10am
clemenz
that sounds good, thank you.
ok i see, i know what i want but not how to install it properly Laughing
i need someone to install me the stuff...
i have a seperate RF modulator that should then be between the digital and the old tuner!
Post #406894 29th Sep 2016 12:16am
TamHare
Scotland 2005 Range Rover Vogue Td6 Monte Carlo Blue
How did you get on with this project?
I'm thinking of doing the same.
Post #442360 22nd Jun 2017 10:50pm
Lukie
2002 Range Rover Vogue 4.4 V8 Zambezi Silver
Best thing to do is upgrade the tv unit, the conversion I do uses the head unit buttons, has usb input looks stock
Post #442376 23rd Jun 2017 7:52am
TamHare
Do you have any more Information about the upgrade you do ie the parts etc I'd need to do it myself or is this a service you provide? I've the 2005 touch screen model
Post #442424 23rd Jun 2017 1:40pm
Mane_Ugle
Sorry for waking this again but would this work
https://www.onbuy.com/gb/hdmi-to-rf-coaxia...6AQAvD_BwE
Post #608604 8th Oct 2021 2:52am
Page 3 of 3 <123
