Home > Technical (L322) > Steering Question |
Britishlion Member Since: 04 Aug 2012 Location: Cheshire Posts: 85 |
16th Sep 2012 7:45pm |
Pedrochellie Member Since: 23 Feb 2012 Location: Surrey Posts: 82 |
Doesn't look like anyone knows anything, at least not today Britishlion!
16th Sep 2012 9:10pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35384 |
you might be thinking of the servotronic valve which regulates the pressure of the steering fluid..the most common sympton of this valves failure is heavy steering when de-accelarating because the faulty valve can't keep up with change in speed..it might be your problem and is very easy to change...do a search for more info.. ... - .- -.
16th Sep 2012 9:14pm |
Thanks Stan,
16th Sep 2012 9:31pm |
the best way I have found is to encompass the word/sentance with double quotation marks, ie "steering" ..this fococuses the search.. ... - .- -.
17th Sep 2012 6:40am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
Remaining fococused ()
17th Sep 2012 7:27am |
Thanks Stan and Joe!
17th Sep 2012 7:47am |
pedro, try revving the engine [out of gear] before you manoeuvre to get the steering fluid circulating properly, then try reversing/turning..if at this point you dont get the judder then its the servotronic valve, if indeed you do still get the judder then its something else.. ... - .- -.
17th Sep 2012 7:53am |
Do you get a sense of which side of the car it is coming from or is it general?
17th Sep 2012 7:56am |
sorry tim, 'very easy' it was for me.. ... - .- -.
17th Sep 2012 7:58am |
Thank again Guys
17th Sep 2012 8:02am |
@ £600 plus fitting ?? (so probably double at main stealer !!) .
17th Sep 2012 8:24am |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
Stratstones quoted me £1800 for a new steering rack ! Turned out the fault had nothing to do with the rack, just a bolt that could have been tighter on a suspension arm. Previously..
17th Sep 2012 10:35am |
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 |
My '02 also does this and has been for some time.
17th Sep 2012 11:59am |
