![]() | Home > General > 2009/2010 europe dvd satnav disc |
hi, looks like there not a prob to talk about sat nav disc, remember if your car is pre 05 you will have a mk3 ...cd based and not the mk4 dvd unit, so the upgrade will not work nor will the map.. i have v3.2 with the landrover logo and 2009 map, works 100% dvd, i am doing a new splash for my FFRR .
Still confused re my bog standard 2007 Sat Nav:
SAppie Member Since: 08 Feb 2010 Location: Berkshire Posts: 159 ![]() ![]() |
1. Yes, the firmware update is on the Map disc, just insert it and it will prompt you to upgrade... or you can go to the hidden menu ( hold your finger next to the nav screen at top for about 5 seconds, a number pad pops up, then input the code 134679, and the menu pops up...in here you can check the version, and force an upgrade.) Remember that the upgrades are on each and every nav dvd, so the latest 09/10 has the latest release. My car is the 2007 MY, and had a really old version of software, the new one improved it a lot, such as when you first click on "agree" , it now auto prompts for a destination..... and it now has the ability to "cancel guidance" on the first menu without having to go through loads to find it. there are other bits and pieces, and appears faster. Also obviously the new updated maps. 2. I "PM"-ed you last night....... Enjoy. |
Is there anyone left who hasn't done this upgrade!? The Speed camera warnings are great as are the LPG POI, my previous version had that too. I'm going to do the S/W upgrade this weekend, and will report back. ![]() |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6372 ![]() ![]() ![]() |
Daveo,
Alias Member Since: 14 Oct 2009 Location: Zurich Posts: 70 ![]() ![]() |
If somebody changed it I am ready to buy it. |
jayzee Member Since: 14 Oct 2009 Location: UK Posts: 342 ![]() ![]() |
+1 to Alias and RRUK's posts |
NavTweak and NavSpeak it's a programs intended to change various things in 'navboot' and sound files.
hi dan, still messing around with the map disc, do you have both cameras and lpg stations on the same disc, and in the nav menu if your running v3.2 should give you the option to turn on/off the cameras, does it give you the option on the lpg stations .
Is it also possible to buy the DVD? I've never seen Speed Camera POI in the normal Navigation Disc. |
simonmanx Member Since: 17 Feb 2010 Location: Isle of Man Ballasalla Posts: 157 ![]() ![]() ![]() |
Hi I have had my new Copy/Clone |
hi simon, you wont be asked.. it was the early unit that asked for the code..you will be fine. V8 facelift Range Rover Autobiography 22" wheels.
hi alias, i have the map with the speed cameras but they are for the uk..so no good to you. V8 facelift Range Rover Autobiography 22" wheels.
dubbs Member Since: 21 Feb 2010 Location: SE London Posts: 117 ![]() ![]() ![]() |
Does this also give perspective view? Loved that on the M6 and would love to upgrade the 2007 version I have on the SC to 2009
