Home > Maintenance & Mods (L322) > 4.4 Thermostats - could it be this easy for a lower temp ? |
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 |
It will be interesting to see if it makes a difference!
4th Sep 2012 8:42am |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1379 |
Simes,
4th Sep 2012 8:59am |
Hmmmm...
4th Sep 2012 9:08am |
jay-p Member Since: 26 Aug 2012 Location: SELSTON / NOTTINGHAMSHIRE Posts: 46 |
I think it's a great idea, il be watching this closely one thing I'm not happy with is the pressure as a result of running so hot all the time, I really think the rad wouldn't fail so so easy if it was running cooler, on an older car surely dropping the temp and relieving the pressure a little has got to be a good thing, and like you say it's still within the engines tolerance, just towards the bottom instead of the top |
4th Sep 2012 9:40am |
ric355 Member Since: 02 May 2011 Location: Surrey, UK Posts: 302 |
What weight are you towing? I regularly tow around 2000kg plus a load of tools and things in the back of the car - probably another 200kg's, and never get out of it with it smelling like it has been struggling and I've never had the gearbox overheat or anything. That is obviously quite a way below the 3.5t limit stated in the manual. |
4th Sep 2012 5:47pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3978 |
Are you certain the radiator isn't blocked either on the outside, the inside or both.
4th Sep 2012 6:05pm |
I took an airline to my radiator last year, blowing from the engine side to out the front of the vehicle, amazing the amount of dirt that came out of it |
4th Sep 2012 7:10pm |
I think i need to clarify a couple of points here:
4th Sep 2012 7:23pm |
Well, the part arrived today. visually, its a match. so it should fit and it clearly says 88degC on it. all good so far.
7th Sep 2012 4:46pm |
klf400 Member Since: 10 Sep 2011 Location: forest of dean Posts: 210 |
interesting topic ,
8th Sep 2012 8:05am |
I promised some pictures of the stats:
8th Sep 2012 1:22pm |
Well, quick update. I've simply not had time to do a run to record the old stat temperatures.
16th Sep 2012 12:23pm |
It's good to see it's OK and with no errors - but I still feel you are trying to fix a fault that doesn't exist.
17th Sep 2012 9:41am |
Your right, there is no 'fault' as such.
17th Sep 2012 7:53pm |
