Home > Maintenance & Mods (L322) > Steering rack spindles
Andy
Do they require CV grease? Just need to know before I strip them down this afternoon to replace. I have two new ones, replacing because I can't get the track rod end off!
Post #187338 9th May 2013 8:14am
If you mean the inner tie rod the joint should be already filled with grease
Post #187348 9th May 2013 9:23am
Andy
You're right- it is. Just took it out of the bag and noticed. Wasn't that obvious in the bag!
Thanks
Post #187536 10th May 2013 7:39am
