![]() | Home > Maintenance & Mods (L322) > 4.4 Thermostats - could it be this easy for a lower temp ? |
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 ![]() ![]() ![]() |
It will be interesting to see if it makes a difference!
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1473 ![]() ![]() |
Simes,
Hmmmm...
jay-p Member Since: 26 Aug 2012 Location: SELSTON / NOTTINGHAMSHIRE Posts: 46 ![]() ![]() ![]() |
I think it's a great idea, il be watching this closely |
ric355 Member Since: 02 May 2011 Location: Surrey, UK Posts: 302 ![]() |
What weight are you towing? I regularly tow around 2000kg plus a load of tools and things in the back of the car - probably another 200kg's, and never get out of it with it smelling like it has been struggling and I've never had the gearbox overheat or anything. That is obviously quite a way below the 3.5t limit stated in the manual. |
Are you certain the radiator isn't blocked either on the outside, the inside or both.
I took an airline to my radiator last year, blowing from the engine side to out the front of the vehicle, amazing the amount of dirt that came out of it |
I think i need to clarify a couple of points here:
Well, the part arrived today. visually, its a match. so it should fit and it clearly says 88degC on it. all good so far.
klf400 Member Since: 10 Sep 2011 Location: forest of dean Posts: 210 ![]() ![]() ![]() |
interesting topic ,
I promised some pictures of the stats:
Well, quick update. I've simply not had time to do a run to record the old stat temperatures.
It's good to see it's OK and with no errors - but I still feel you are trying to fix a fault that doesn't exist.
Your right, there is no 'fault' as such.
