Home > General > Torture filling up with diesel
stu
i had the same problem when i swapped from the TD6 to the TDV8.... i soon took peoples advice and turned the pump from 6 o'clock to 12 o'clock and bobs your uncle fuel goes in how you would expect it to... Thumbs Up Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #135006 8th Aug 2012 7:15pm
Dexter
United Kingdom 2017 Range Rover Vogue SE SDV8 Waitomo Grey
Another one who does it upside down Mr. Green
Post #135755 13th Aug 2012 6:15pm
Def90v8
Faulty filler neck
Hi there is a modified filler neck for u all
The plastic contracts and slows the fill
Also if u can see the yellow flap that means its active use the tool also yellow put the two prongs up against the top of the hole they will drop into a hole and the flap will spring away.
Hope this helps
Post #136325 16th Aug 2012 7:29pm
