Home > Maintenance & Mods (L322) > Starting woes! |
I would think glow plugs although it is a "funny" problem. MY 2010 5.0 SC Galway green and sand interior!!
4th Aug 2012 10:50am |
Doubt if it is glow plugs, even when we were down to -22C a couple of years ago I never used my glow plugs and the engine started first time
4th Aug 2012 10:54am |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2625 |
Will give Dan a bell Monday , he hasn't given me his home number yet! |
4th Aug 2012 11:00am |
CPS is £32 from Eurofarts but out of stock |
4th Aug 2012 11:02am |
Would it be an easy install, I can take hings apart but am useless at putting back on! |
4th Aug 2012 11:06am |
Rimmers have them : is this the culprit: http://www.rimmerbros.co.uk/Item--i-NSC100880L a bit pricey from them though! |
4th Aug 2012 11:09am |
Check with Dan for the correct part number
4th Aug 2012 11:15am |
Wow, you are the font of all knowledge!
4th Aug 2012 11:24am |
A dripping injector could cause difficult starting, but not necessarily cause smoke from the exhaust. Expensive to have diagnosed and repaired so making sure everything else is in order before going to the bother of removing them for checking.
4th Aug 2012 11:28am |
Sounds like I need a recommendation for a good indie in tayside, anyone any suggestions? |
4th Aug 2012 11:32am |
Yeah he's also known as Methuselah …. |
4th Aug 2012 11:35am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6405 |
Also may be worth just checking the wiring from the CKP back to the ECM ? .
4th Aug 2012 11:57am |
I do just not met you yet |
4th Aug 2012 12:02pm |
Pity i was down your neck of the woods on Thursday taking the wee one to the Orthodontist at Orchard Drive …. |
4th Aug 2012 12:37pm |
