![]() | Home > Maintenance & Mods (L322) > HDC, Air Suspension & hand brake and ABS light? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35489 ![]() ![]() |
leave it to dry for a while then see if the lights are still there.. ... - .- -.
Glideman Member Since: 11 Sep 2011 Location: Stood next to a broken down Range Rover in Darwen Posts: 112 ![]() ![]() ![]() |
dont know why you're having the lights unless you dis-connected the battery and didnt reset the steering parameters....
Saint.v8 Member Since: 13 Jun 2012 Location: UK< Surrey - Near the Middle Close to Some Green Bits Posts: 94 ![]() ![]() ![]() |
Try disconnecting the battery waiting 15 minutes then reconnect...
Thanks for all the help guys, I'm off to disconnect the battery to see if that helps and have just Googled the
piecost76 Member Since: 19 Jul 2010 Location: Nr Sevenoaks, Kent Posts: 296 ![]() ![]() |
Is "as far away from any Land Rover product as I can get" anywhere near Kent?
It is probably water got into the ABS module and causing poor connection. This will cause all the other faults as all are on the same loop and a ABS fault stops the power getting to the other sensors, causing an alert.
paneldamage Member Since: 11 Nov 2010 Location: Preston Posts: 222 ![]() ![]() |
It could also be a sign of a tired battery- I presume you were cleaning car, lots of opening/closing doors, etc, and these kinds of error messages then pop up. My experience is that the car is sensitive to low batt voltages. The 15 min disconnect, followed by resetting the steering angle lock to lock should help. |
jim2RRs Member Since: 07 Feb 2012 Location: Genesee, Colorado Posts: 147 ![]() ![]() ![]() |
pricey for a small box. Well, that's one way to look at it. If it'll make you feel any better, I can send you a VERY LARGE cardboard box you can put the IIDTool in. Alternatively, you could see what Blackbox Solutions charges for their magic box. Then perhaps ring up the dealer and ask if you can buy the official Land Rover diagnostic machine. And then jump online and buy the IID Tool in about 2 seconds. Jim 2000 NAS HSE 2005 NAS HSE |
+1 what jim said..
The Hawkeye is under £300 and is not VIN-tied so you could use it on any L322.
I suggest to have a good look at all your earth/ground connections as well as the clamps on the battery. Take them off, clean off any corrosion. On the battery clamps, put a thin coat of Vaseline to prevent future corrosion on the other connections use a proper electrical contact cleaner and if you don't have any, WD-40 also does a decent job just not as good as a good electrical contact cleaner. MY 2010 5.0 SC Galway green and sand interior!!
This morning I disconnected the battery. Took off the box which was under the windscreen & behind the battery & cleaned all the connections & applied some contact switch cleaner and then some silicone spray after drying it out. The plastic box was slightly open so that may have caused the leak into the connections.
Not forgetting rswsolutions RAC Tool (not tied to VIN) @ £160 but would take @ three weeks to get here from Denver! .
