![]() | Home > Maintenance & Mods (L322) > Plenty refrigerant but no cold aircon: EDITED - and no heat! |
Tuts Member Since: 24 May 2012 Location: Bishop’s Stortford, Herts Posts: 201 ![]() ![]() ![]() |
How do you know there's refrigerant in there?
Budgie Member Since: 09 Jul 2012 Location: Stornoway Posts: 267 ![]() ![]() |
Does the regas kit have a gauge on it that shows the system pressure?
The only way to find out how much refrigerant is in an ac system is to evacuate it and weigh it. You can't determine the quantity by measuring pressure in the system.
misteralz Member Since: 30 May 2012 Location: Aberdeenshire Posts: 148 ![]() ![]() ![]() |
Seems it's probably not an aircon issue at all. Plenty refrigerant in both sides - yeah, checked with a gauge - and checking the temperatures from the vents with my hand-held IR temp gauge sees to real variation in temperature from 16 to whatever the max is on the dial... So it's a control issue which is a bit of a |
Isn't there a temp sensor/thermostat type thing in the centre console near the heater controls ? Wouldn't have the foggiest how the to test it though! Looks like a little black vent ? 2003 Vogue 4.4 V8 Java Black |
The best idea would be to connect it to a diagnostic unit to search for the fault.
Since you have no heat and no cold, it sounds like the flaps directing the air flow may be the issue.
andyleeds Member Since: 31 Dec 2010 Location: west yorks Posts: 958 ![]() ![]() ![]() |
i had this issue in an old rangie i used to have (02 plate) and i seem to remember it was actually a resistor that was shot which controls the temp.... was a little part but still cost a Ł200 to fix i think |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35485 ![]() ![]() |
guessing it could be the FSR or the blend flap motors.. ... - .- -.
FSR |
FSR? So, what's that, then? |
fsr = final stage resister...
Thanks - looks a really easy job. Where's the best place to get a new FSR? 2003 Vogue TD6/1992 Classic 300TDi/2x 1991 Golf GTI/1966 Volkswagen Kombi/2x 1968 Volkswagen Kombi/Probably something I've forgotten... |
dan @ duckworths or ebay http://www.ebay.co.uk/itm/LAND-ROVER-RANGE...1c28de9422
