Home > Maintenance & Mods (L322) > Plenty refrigerant but no cold aircon: EDITED - and no heat! |
Tuts Member Since: 24 May 2012 Location: Bishop’s Stortford, Herts Posts: 201 |
How do you know there's refrigerant in there?
19th Jul 2012 7:39pm |
Budgie Member Since: 09 Jul 2012 Location: Stornoway Posts: 267 |
Does the regas kit have a gauge on it that shows the system pressure?
19th Jul 2012 7:48pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3972 |
The only way to find out how much refrigerant is in an ac system is to evacuate it and weigh it. You can't determine the quantity by measuring pressure in the system.
19th Jul 2012 8:07pm |
misteralz Member Since: 30 May 2012 Location: Aberdeenshire Posts: 148 |
Seems it's probably not an aircon issue at all. Plenty refrigerant in both sides - yeah, checked with a gauge - and checking the temperatures from the vents with my hand-held IR temp gauge sees to real variation in temperature from 16 to whatever the max is on the dial... So it's a control issue which is a bit of a . So, first things first, are there any simple checks I can perform? I can get all the fan speeds and the umpteen buttons to control the airflow work, so what's likely to be wrong? 2003 Vogue TD6/1992 Classic 300TDi/2x 1991 Golf GTI/1966 Volkswagen Kombi/2x 1968 Volkswagen Kombi/Probably something I've forgotten... |
25th Jul 2012 11:38am |
Isn't there a temp sensor/thermostat type thing in the centre console near the heater controls ? Wouldn't have the foggiest how the to test it though! Looks like a little black vent ? 2003 Vogue 4.4 V8 Java Black |
25th Jul 2012 11:58am |
The best idea would be to connect it to a diagnostic unit to search for the fault.
25th Jul 2012 12:20pm |
Since you have no heat and no cold, it sounds like the flaps directing the air flow may be the issue.
25th Jul 2012 1:34pm |
andyleeds Member Since: 31 Dec 2010 Location: west yorks Posts: 952 |
i had this issue in an old rangie i used to have (02 plate) and i seem to remember it was actually a resistor that was shot which controls the temp.... was a little part but still cost a Ł200 to fix i think |
25th Jul 2012 1:47pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35274 |
guessing it could be the FSR or the blend flap motors.. ... - .- -.
25th Jul 2012 1:51pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
FSR
25th Jul 2012 2:05pm |
FSR? So, what's that, then? 2003 Vogue TD6/1992 Classic 300TDi/2x 1991 Golf GTI/1966 Volkswagen Kombi/2x 1968 Volkswagen Kombi/Probably something I've forgotten... |
25th Jul 2012 3:15pm |
fsr = final stage resister...
25th Jul 2012 4:49pm |
Thanks - looks a really easy job. Where's the best place to get a new FSR? 2003 Vogue TD6/1992 Classic 300TDi/2x 1991 Golf GTI/1966 Volkswagen Kombi/2x 1968 Volkswagen Kombi/Probably something I've forgotten... |
27th Jul 2012 9:51am |
dan @ duckworths or ebay http://www.ebay.co.uk/itm/LAND-ROVER-RANGE...1c28de9422
27th Jul 2012 9:57am |
