Home > Technical (L322) > hissing from driver side wheel arch |
Sounds like the air bag, time to spray the soapy suds on and test for leaks |
15th Jul 2012 11:05am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
Does hissing go away when in standard height or access height?
15th Jul 2012 12:26pm |
Island 4x4, Matt. Best prices on struts.
15th Jul 2012 4:52pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Matt, stick it up on high and gently lift the offending wheelarch up (put your backside against it and lift the wheelarch) if you get a louder hiss, its the bag... Be gentle though as your wings are alloy...
15th Jul 2012 6:33pm |
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 |
it wouldnt make it to high it doesnt even make it to standard height the hissing is very loud as soon as it starts to rise it past access mode
15th Jul 2012 8:14pm |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
Sounds like a bag matt. Get some soapy water on it to prove. Use a trolley jack to get the offending corner to raise if needed.
15th Jul 2012 8:40pm |
sgtgeall Member Since: 14 Apr 2012 Location: Chichester Posts: 11 |
i had the same hissing yesterday + wouldn't raise at all.. just had it recovered to the local dealer, will keep you posted. 2008 Vogue SE TDV8 Stornoway Grey, Jet Oxford Leather & Piano Black |
16th Jul 2012 6:45am |
