Home > Technical (L322) > hissing from driver side wheel arch
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
Hi all
Parked my car on a kerb this morning outside my house to wash it, raised the suspension to off road to clean the wheel arches, and i started to hear a hissing noise coming from the drivers side wheel arch. Is this the bag thats gone? or do you think it could be the crosslink valve?
Matt
Post #131177 15th Jul 2012 10:43am
Sounds like the air bag, time to spray the soapy suds on and test for leaks
Post #131179 15th Jul 2012 11:05am
Does hissing go away when in standard height or access height?
If so most definitely air bag.
So unless it is going into the stealers: http://www.fullfatrr.com/gallery/thumbnails.php?album=359 .
Post #131193 15th Jul 2012 12:26pm
SteveMFr
Site Sponsor
Island 4x4, Matt. Best prices on struts.
What's up with the car pc?
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #131234 15th Jul 2012 4:52pm
Matt, stick it up on high and gently lift the offending wheelarch up (put your backside against it and lift the wheelarch) if you get a louder hiss, its the bag... Be gentle though as your wings are alloy...
Craig Thumbs Up
Post #131248 15th Jul 2012 6:33pm
mattstevenson2005
it wouldnt make it to high it doesnt even make it to standard height the hissing is very loud as soon as it starts to rise it past access mode
matt
Post #131263 15th Jul 2012 8:14pm
Sounds like a bag matt. Get some soapy water on it to prove. Use a trolley jack to get the offending corner to raise if needed.
How's the car pc going? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #131268 15th Jul 2012 8:40pm
sgtgeall
United Kingdom 2008 Range Rover Vogue SE TDV8 Stornoway Grey
i had the same hissing yesterday + wouldn't raise at all.. just had it recovered to the local dealer, will keep you posted. 2008 Vogue SE TDV8 Stornoway Grey, Jet Oxford Leather & Piano Black
Post #131305 16th Jul 2012 6:45am
