Home > In Car Electronics (L322) > BM54 Amp Upgrade
Page 4 of 9 <123456789>
daveo
sounds good Thumbs Up V8 facelift Range Rover Autobiography 22" wheels.
Post #131239 15th Jul 2012 5:59pm
daveym
United Arab Emirates
I received mine back from Baris today ( I only sent it on Mon) and I couldn't wait to get it fitted into the RR. I had the firmware upgrade and repair as well as IPhone and aux cable attached.
I went a little bit further and used the little tray in front of the gear selector and made my own iPhone dock. Meaning I just get in the car and drop it in the cradle and it charges and plays my music. It took a while routing the very long cable through the car but I got there in the end. I would post pics but working out how to do it.
I would definately recommend this upgrade. Very Happy
Post #135206 9th Aug 2012 9:37pm
daveo
lets have some photos then Shocked V8 facelift Range Rover Autobiography 22" wheels.
Post #135207 9th Aug 2012 9:50pm
daveym
Trying Daveo Question
Post #135208 9th Aug 2012 9:51pm
daveo
is the docking station the type from maplins V8 facelift Range Rover Autobiography 22" wheels.
Post #135224 9th Aug 2012 10:55pm
its been posted before dave,
http://www.fullfatrr.com/forum/topic2612.h...phone+dock ... - .- -.
Post #135266 10th Aug 2012 8:29am
Deasy
so does this do away with the need for an intravee then??
because am i right in thinking that it works out a little cheaper than in intravee?
Post #135271 10th Aug 2012 9:00am
daveym
I didn't use a dock from Maplins. I had the centre console out and basically with the use of a dremel and a nervous steady hand cut a perfect slot for a iPhone cable to slot through.
I can't control the iPhone from the steering controls but it's easy enough to reach so i don't think it's the same as an intravee.
Post #135359 10th Aug 2012 1:50pm
Baris
Thought you guys might want to know about my Analogue to Digital Conversion, that wont cost the same as a 50" plasma TV.
Here is a review http://forums.m3cutters.co.uk/showthread.php?t=62000[/url]
Post #142999 25th Sep 2012 3:48pm
mjdronfield
I'd do a new thread for this if I were you mate.
Looks excellent.
I have a BMW hybrid tuner installed, so won't be partaking in this particular upgrade I'm afraid.
I'm on the look out for some upgraded speakers from a 2005 onwards model if you come across any............
Mark 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #143001 25th Sep 2012 3:56pm
jim2RRs
United States 2005 Range Rover HSE 4.4 V8 Chawton White
I have a US model year 2005.
It has the touchscreen (in US, non-touchscreen was '03 & '04).
Does the firmware upgrade apply to this model?
US & UK model years don't match, apparently.
Or does the firmware upgrade bring a non-touchscreen up to what I already have? Jim
2000 NAS HSE
2005 NAS HSE
Post #143094 26th Sep 2012 3:53am
mjdronfield
This is just for BMW based non touchscreen I'm afraid. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #143100 26th Sep 2012 7:33am
Andy
This and the digital tv thread needs to be a sticky 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #143622 29th Sep 2012 9:02am
Can someone (hopefully Baris) please clarify the modifications required for AUX - IN ?
1. I understand that BM54 pre 09/2002 didn't have it "enabled"
2. Post 09/2002 you could just plug in the cable and it would work (as evidenced by all the Beemer users doing it)
3. For pre 09/2002 models, is there further soldering to do inside the BM54 unit, to connect the external pins to something internal?
4. For pre 09/2002 models, is there an additional a firmware (chip) / software (flash) upgrade to the BM54 required as well?
5. In Steve Mfr 's post, he shows a little board with capacitors and resistors. I understand you only need this if you don't have something "plugged in" to your aux-in?
Given I have an Apr 2002 car, I am assuming I have the pre 09/2002 BM54. It has the flat pins. Radio works fine, so was hoping to attempt the aux-in mod myself. Can do the soldering (if I knew what to solder to what!) but don't have the tech if firmware/software is required. .
Post #154864 2nd Dec 2012 11:01am
bump Confused .
Post #155843 6th Dec 2012 7:09pm
