![]() | Home > Technical (L322) > IIDTool from gap diagnostics ***Q & A *** |
Hi Alan,
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6766 ![]() ![]() ![]() |
Thanks Steve, I'll do that and give it a go!
ok, i have been looking at the IIDTOOL, I have the rover com unit from RSW and dont get me wrong its great but its not moving along as quick as i would like it to, still waiting for the LCM programming to come along as well as the rain sensor settings,
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35634 ![]() ![]() |
the IIDTool only connects to the laptop/pc when new firmware is needed dave...stick in the obd port and the settings are adjusted from the cruise controls on the steering wheel... ... - .- -.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16336 ![]() ![]() ![]() |
Thank you Steve, i did'nt even realise you have done it... Ill get on it now sir... Craig ![]() ![]() ![]() |
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 ![]() ![]() |
The key bong used to really pi55 me off - IID Tool has made it magically disappear |
tbh i didnt realise how annoying it was until i dis-abled it. ... - .- -.
drakes Member Since: 26 Jan 2009 Location: Consett Posts: 371 ![]() ![]() ![]() |
I am trying to update my soft ware but when I press the Find Device button it says it can not find it although the laptop has already said it has found new hardware. Any suggestions from you more computer literates would be good thanks.
reboot the laptop and try again.. ... - .- -.
Still no luck. It bongs when I plug it in but does not show up as connected in "my computer" and the firmware updater says its not there. 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
by coincidence i had this with my iphone today..try different a cable, re-install the gap downloader..all the kind of things that might be causing your problem..
I have tried a different cable and reloading the software, perhaps its time for an email to Gap. The unit works fine on the vehicle 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
unlikely it would be the unit if it works on the range...can you try another laptop/pc.. ... - .- -.
update on mine,
