![]() | Home > Technical (L322) > Reduced Engine Performance |
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 ![]() ![]() |
It'll be the charge cooler pump wiring - do a search, common problem on the SC, a lot of the pumps were wired up back to front so the pump runs backwards - when you drive it hard the charge temp gets too high and it restricts performance........
That, or rubbish fuel (can happen) .... Land Rover Addict
salb Member Since: 25 Feb 2012 Location: blackburn Posts: 332 ![]() ![]() ![]() |
Rubbish fuel that's interesting filled up at tesco with there normal unleaded £100,
Iid tool full diagnostics, please can someone tell me the model number I need,
Update ...........
Anyone want to rent out the fan removal tool/removal of aux water cooling pump
You don't need to remove the fan, it's the small cooling pump at the LHS of the radiator (or RHS) when looking at it - quite an easy job. Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather..... |
Thanks
