Home > Maintenance & Mods (L322) > Anything I need to know before removing the battery? |
Switch everything off, remove the key from the ignition and go and have a cup of tea/coffee then in 20 minutes come back and disconnect the negative terminal first, then the positive terminal |
10th Jul 2012 10:47pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
Everything you need to know about disconnecting the battery:
10th Jul 2012 11:06pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35360 |
...or in our very own wiki. http://www.fullfatrr.com/wiki/Battery_dis-connection_procedure ... - .- -.
11th Jul 2012 7:58am |
JW911 Member Since: 09 Dec 2008 Location: Hampshire, UK Posts: 235 |
Ta. Now, anyone got any tips on how to lift it? 2012 4.4 TDV8 Westminster
11th Jul 2012 9:57am |
if you have the bonnet in service mode and have a step to stand on, it shouldnt be that bad.. ... - .- -.
11th Jul 2012 9:58am |
Yeah fingertips ...
11th Jul 2012 10:01am |
T111RDY Member Since: 21 May 2012 Location: Dunbar Posts: 187 |
It is however, an absolute b d to lift, even with the above! l:OolΞΞΞΞΞΞloO:l
11th Jul 2012 10:04am |
Battery should have handles on it? If not you should be able to slide some webbing underneath. depends on the size of what is in there at the moment.
11th Jul 2012 11:29am |
