Home > Maintenance & Mods (L322) > Anything I need to know before removing the battery?
JW911
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
I need to replace my windscreen wiper relay, as detailed in another thread. The battery appears to need to be removed before I can get to it - unless someone knows another way......
Knowing how sensitive FFRR are to escaping wiggly amps, is there anything I should do prior to disconnecting the battery to remove it (assuming I can actually lift it)?
Thanks. 2012 4.4 TDV8 Westminster
2007 3.6 TDV8 Vogue - gone!
2003 V8 HSE (LPG) - gone!
2018 F-Pace 25t Portfolio
1974 LR Series III Lightweight FFR
2014 BMW 640i Gran Coupe
Post #130379 10th Jul 2012 11:42pm
Switch everything off, remove the key from the ignition and go and have a cup of tea/coffee then in 20 minutes come back and disconnect the negative terminal first, then the positive terminal Thumbs Up
Post #130387 10th Jul 2012 11:47pm
Everything you need to know about disconnecting the battery:
http://bimma.me.uk/2010/03/12/disconnectin...ation-rhd/ .
Post #130390 11th Jul 2012 12:06am
...or in our very own wiki. http://www.fullfatrr.com/wiki/Battery_dis-connection_procedure ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #130412 11th Jul 2012 8:58am
JW911
Ta. Now, anyone got any tips on how to lift it? Big Cry 2012 4.4 TDV8 Westminster
Post #130428 11th Jul 2012 10:57am
if you have the bonnet in service mode and have a step to stand on, it shouldnt be that bad.. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #130430 11th Jul 2012 10:58am
Yeah fingertips ... Laughing Embarassed
Bonnet straight up in the vertical position small pairs of steps at the side disconnect and lift ... Viola Thumbs Up
Beat me to it Mr Mod Laughing
Post #130431 11th Jul 2012 11:01am
T111RDY
Scotland 2002 Range Rover Vogue 4.4 V8 Java Black
It is however, an absolute b Censored d to lift, even with the above! l:OolΞΞΞΞΞΞloO:l
2002 4.4 Vogue Java Black
Post #130437 11th Jul 2012 11:04am
Battery should have handles on it? If not you should be able to slide some webbing underneath. depends on the size of what is in there at the moment.
Make sure to put some protective padding in front of the battery area to create a "landing area". There are some important pipes in that area .
Post #130456 11th Jul 2012 12:29pm
