![]() | Home > Maintenance & Mods (L322) > Anything I need to know before removing the battery? |
Switch everything off, remove the key from the ignition and go and have a cup of tea/coffee then in 20 minutes come back and disconnect the negative terminal first, then the positive terminal |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
Everything you need to know about disconnecting the battery:
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35641 ![]() ![]() |
...or in our very own wiki. http://www.fullfatrr.com/wiki/Battery_dis-connection_procedure ... - .- -.
JW911 Member Since: 09 Dec 2008 Location: Hampshire, UK Posts: 260 ![]() ![]() |
Ta. Now, anyone got any tips on how to lift it? |
if you have the bonnet in service mode and have a step to stand on, it shouldnt be that bad.. ... - .- -.
Yeah fingertips ... |
T111RDY Member Since: 21 May 2012 Location: Dunbar Posts: 187 ![]() ![]() ![]() |
It is however, an absolute b |
Battery should have handles on it? If not you should be able to slide some webbing underneath. depends on the size of what is in there at the moment.
