Home > Maintenance & Mods (L322) > Wind noise beware !!! |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7719 |
9th Jul 2012 6:13pm |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
Are you sure it was the original screen?? Scary thought all the same.. Previously..
9th Jul 2012 6:52pm |
max abbi Member Since: 19 Oct 2010 Location: Newtownabbey Posts: 18 |
Very scary, imagine losing a windscreen at 70+ mph, doesn't bear thinking about!
9th Jul 2012 8:25pm |
ahebron Member Since: 01 Jan 2012 Location: The other Eastbourne Posts: 341 |
My FFRR had a pet mouse. When I opened up the dash all the insulation was in chewed up piles and mouse poo and wee was found. I do hope its gone Adrian VW Amarok 2014 Highline auto |
10th Jul 2012 8:07am |
I didn't think Range Rovers of our era supported USB..........
10th Jul 2012 8:58am |
One should never say never, but I have a very hard time imagining that it was a factory installed screen. As you said, the 'genuine screen' does not identify it as ex-factory and having had 2 screen replacements in the past 12 months (one to repair a stone chip that turned into a huge crack with the windshield heater and the second to repair the said heater... ) and having used the same glue on boats, car glass, etc I can tell you - it is hard to get it NOT to stick. About the only 2 things you can do is either have a dirty (oily, greasy) surface or allow too long before setting the windshield in place so that the glue has partially cured. And neither of these scenarios is likely on an assembly line yet more than possible by an aftermarket fitter. Not pleasant either way, tho! RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
10th Jul 2012 9:40am |
Windscreen Dave Member Since: 28 Jun 2012 Location: Lincoln Posts: 29 |
I agree with Steve I have changed plenty of these screens and often on RR,s that are under a year the customer specifies that he wants it with the land rover badge so there would be no way of telling that it has had a previous screen in it. One of the main reasons that the glue won't stick to the screen is if the fitter hasn't cleaned the obs band (black bit around outside of glass) properly as during manufacture screens go through a silicone wash and if this is not cleaned off properly the glue won't stick. I also think that during the first few years of ownership this would have been picked up simply due to things like you noticed of wind noise. Still doesn't get away from the fact that there are some bad fitters out there as I suppose with all walks of life. Had a similar situation yesterday on a 3 series BMW i put my suckers on the glass and simply lifted it out without any cutting required customer was horrified. As was I. |
11th Jul 2012 6:38pm |
