Home > Technical (L322) > ride height |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6410 |
Could be that....(maybe your brothers needs resetting!) or
15th Jun 2012 12:47pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35412 |
access/standard height ?
15th Jun 2012 1:13pm |
Your brother secretly owns an IIDTool or EASControl...
15th Jun 2012 1:17pm |
or RAC .
15th Jun 2012 1:56pm |
Saint.v8 Member Since: 13 Jun 2012 Location: UK< Surrey - Near the Middle Close to Some Green Bits Posts: 94 |
When I picked mine up, I noted it was sitting lower and the ride not so supple....
15th Jun 2012 2:03pm |
igore Member Since: 20 Oct 2010 Location: portsmouth Posts: 118 |
cheers chaps for your comments ONE LIFE LIVE IT |
17th Jun 2012 11:37am |
17th Jun 2012 11:53am |
waiting for brother to come round next i think his is on 19s and mine are 20s ONE LIFE LIVE IT |
17th Jun 2012 12:21pm |
After doing my Rover All Comms recalibration I appear to be @ 800mm all round (on 20" rims). Is there a standard measurement we can verify against? .
17th Jun 2012 2:57pm |
33CHINACARS Member Since: 14 Apr 2011 Location: Tyrendarra, Victoria, Australia Posts: 381 |
Someone correct me if I'm wrong . But diameter of tyres should be the same for 18-19-20" rims so ride height would be the same regardless of rim size
17th Jun 2012 2:58pm |
My Calibration was carried out by Land Rover....I run on 19" rims with 255/50R19 boots....
17th Jun 2012 3:18pm |
chaps i measured from centre of wheel to the wheel arch and got 490mm all round this just dont seem right.
26th Jun 2012 5:24am |
OK, so if you read the references above once more I think you should be measuring to the BOTTOM of the wheel rim, not the centre. This would add about half a wheel diameter, so 9.5" (about 240mm) to your 490mm, thus giving you 730mm.
26th Jun 2012 6:45am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3979 |
No you're not missing anything, you are right, the wheel rim dia will mean the wheel arch to the bottom of the rim measurement will vary according to which wheel is fitted.
26th Jun 2012 7:03am |
