![]() | Home > Technical (L322) > ride height |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
Could be that....(maybe your brothers needs resetting!) or
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35619 ![]() ![]() |
access/standard height ?
Your brother secretly owns an IIDTool or EASControl...
or RAC |
Saint.v8 Member Since: 13 Jun 2012 Location: UK< Surrey - Near the Middle Close to Some Green Bits Posts: 94 ![]() ![]() ![]() |
When I picked mine up, I noted it was sitting lower and the ride not so supple....
igore Member Since: 20 Oct 2010 Location: portsmouth Posts: 118 ![]() ![]() ![]() |
cheers chaps for your comments |
What was the outcome on yours? Was it low? |
waiting for brother to come round next i think his is on 19s and mine are 20s ONE LIFE LIVE IT |
After doing my Rover All Comms recalibration I appear to be @ 800mm all round (on 20" rims). Is there a standard measurement we can verify against? .
33CHINACARS Member Since: 14 Apr 2011 Location: Tyrendarra, Victoria, Australia Posts: 381 ![]() ![]() ![]() |
Someone correct me if I'm wrong . But diameter of tyres should be the same for 18-19-20" rims so ride height would be the same regardless of rim size
My Calibration was carried out by Land Rover....I run on 19" rims with 255/50R19 boots....
chaps i measured from centre of wheel to the wheel arch and got 490mm all round this just dont seem right.
OK, so if you read the references above once more I think you should be measuring to the BOTTOM of the wheel rim, not the centre. This would add about half a wheel diameter, so 9.5" (about 240mm) to your 490mm, thus giving you 730mm.
No you're not missing anything, you are right, the wheel rim dia will mean the wheel arch to the bottom of the rim measurement will vary according to which wheel is fitted.
