Home > General > Disappointed/disillusioned etc.
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Getting itchy again.
Test drove a 3.6 TDV8- newer seats are crap, didn't like the lag between accelerator press and movement.
I know I could have it mapped but that's another expense plus would void warranty etc. So 3.6 can prob #9.
Can't afford a 4.4 TDV8 so I don't know what to do! Get saving for a 5.0? Getting a hankering for a sportier car.
Big Cry
Post #127014 20th Jun 2012 6:14pm
fisha
Interesting you talk about the lag.
Just test drove my bro in law's audi A5 with a 3.0 diesel auto. Whilst it was properly quick once going, the standstill lag was awful. It did make me wonder about the tdv8 and whether it had any.
He had a shot in my 4.4 petrol and couldn't believe how direct the throttle response was. V8 or else ...
Post #127028 20th Jun 2012 7:57pm
mzplcg
Throttle lag on 3.6 TDV8 is nothing short of dire. Measurable in centuries. Most diesels have this for some reason, yes a re-map does seem to sure it so I'm unsure as to what parameters are causing it in the map. Obviously something emissions related I reckon.
But yes, me too. Looking at a hot hatch to run as well as the FFRR.
Post #127033 20th Jun 2012 8:13pm
verydisco
Re: Disappointed/disillusioned etc.
Hi
I had the same feeling with mine until it was "BAS boxed", then this was largely corrected.
Waranty void is not an issue as you can withdraw the tune with the Box in a matter of seconds.
Give it a try or try a friend's tuned TDV8. Thumbs Up l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #127036 20th Jun 2012 8:18pm
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
Go for a 4.2 sc and get the pulleys done?
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #127056 20th Jun 2012 9:40pm
Stephen.125
Might be a way to get some joy back in my 55 s/c, thanks something to think about Thumbs Up
Post #127057 20th Jun 2012 9:42pm
TheAllSeeingPie
I've been looking at a place in Sheffield that do them for not a lot. Top is £295 fitted and bottom is about £435 fitted, although if you get the bottom one done it could cost more as thy recommend replacing any knackered bearings thy find. Probably worth getting th gearbox oil checked too. Best thing about pulley changes is that the ecu adjusts automatically, although a remap will release even more power.
Post #127058 20th Jun 2012 9:45pm
CSK
France 2013 Range Rover Autobiography 5.0 SC V8 Causeway Grey
All diesels seem to have lag especially from standstill or very low speed, once you are on the go there's almost none.
It gets annoying when you're doing a lot of low speed traffic.
Both Sport and FF 3.6 TDV8 I've owned had the same "problem", I've driven a 4.4TDV8 and although it is less noticable than in the 3.6 it is still there and driven the 4.2 and a 5L Supercharged also on loan (yes I have a friendly dealer) and there's none.
Post #127061 20th Jun 2012 9:49pm
Stephen.125
Thumbs Up Cheers!
Wonder how the 'sealed for life' charger oil holds up, maybe worth an overhaul. I'm pretty interested to see if any of the factory endowed horses have 'bolted' over 6 years of use.
Either that or test drive that M6 I've been looking at Whistle
Post #127062 20th Jun 2012 9:51pm
TheAllSeeingPie
Using an M5/M6 in traffic is akin to bring raped by Mike Tyson due to the terrible gearbox. Out on an open road they are immense though.
Post #127064 20th Jun 2012 9:54pm
stu
my tuned TDV8 has very little noticable lag at all, but one way to help cut down on it in standard tune is to use the command shift, especially about town. just move it to the gear you want and it will be on boost and ready to do what you want. Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #127069 20th Jun 2012 10:37pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
<baffled> I went from a 5.0SC (after a 4.2SC and a 4.4N/A) to a 3.6 - what lag are we on about???????? Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #127071 20th Jun 2012 10:39pm
stu
there is a certain amount especially from a stand still, i don't think it is as drastic as some people are making out myself!! just my opinion of course.
but as i said if you drive it in manual mode it picks up so much quicker.
alternatively just spend a couple of hundred and get it mapped...you know it makes sense!! Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #127072 20th Jun 2012 10:43pm
Happy, the 6 speed ZF box is only sealed for life on the 3.6 TDV8 on petrol FFRR's Land Rover do not say it's sealed for life and the hand book gives you the correct oil but not the interval , I suppose I should look it up in the Servis manuel 2008 MY Supercharged
Post #127074 20th Jun 2012 10:46pm
0cj0
Laughing
I know exactly what your on about. Used to wind me up no end!
Post #127075 20th Jun 2012 10:46pm
