![]() | Home > General > Disappointed/disillusioned etc. |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1472 ![]() ![]() |
Interesting you talk about the lag.
Throttle lag on 3.6 TDV8 is nothing short of dire. Measurable in centuries. Most diesels have this for some reason, yes a re-map does seem to sure it so I'm unsure as to what parameters are causing it in the map. Obviously something emissions related I reckon.
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
Hi I had the same feeling with mine until it was "BAS boxed", then this was largely corrected. Waranty void is not an issue as you can withdraw the tune with the Box in a matter of seconds. Give it a try or try a friend's tuned TDV8. ![]() Current RANGE ROVER Vogue 4.4L SDV8 - 2013 - Indus Silver, on Almond. RANGE ROVER Vogue 4.4L V8 - 2002 - ex-2003 G4 Challenge Event Vehicle, Stage 3: Australia RANGE ROVER HSE 4.4L V8 - 2004 - one-of-one Overfinch RANGE ROVER P38a 4.0L V8 - 1999 - ex-2000 TReK Event Vehicle: South Africa Previous: RANGE ROVER Vogue 4.4L TDV8 - 2012 - RANGE ROVER 3.6L TDV8 x3 - RANGE ROVER Td6 x1 - RANGE ROVER Classic 3.5L V8 x1 |
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 ![]() ![]() ![]() |
Go for a 4.2 sc and get the pulleys done?
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1522 ![]() ![]() |
Might be a way to get some joy back in my 55 s/c, thanks something to think about |
I've been looking at a place in Sheffield that do them for not a lot. Top is �295 fitted and bottom is about �435 fitted, although if you get the bottom one done it could cost more as thy recommend replacing any knackered bearings thy find. Probably worth getting th gearbox oil checked too. Best thing about pulley changes is that the ecu adjusts automatically, although a remap will release even more power.
CSK Member Since: 15 Oct 2010 Location: St Tropez Posts: 750 ![]() ![]() ![]() |
All diesels seem to have lag especially from standstill or very low speed, once you are on the go there's almost none.
Using an M5/M6 in traffic is akin to bring raped by Mike Tyson due to the terrible gearbox. Out on an open road they are immense though.
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 ![]() ![]() ![]() |
my tuned TDV8 has very little noticable lag at all, but one way to help cut down on it in standard tune is to use the command shift, especially about town. just move it to the gear you want and it will be on boost and ready to do what you want. Current: TDV8 (3.6) RRS HSE
<baffled> I went from a 5.0SC (after a 4.2SC and a 4.4N/A) to a 3.6 - what lag are we on about???????? Land Rover Addict
there is a certain amount especially from a stand still, i don't think it is as drastic as some people are making out myself!! just my opinion of course.
Happy, the 6 speed ZF box is only sealed for life on the 3.6 TDV8 on petrol FFRR's Land Rover do not say it's sealed for life and the hand book gives you the correct oil but not the interval , I suppose I should look it up in the Servis manuel 2008 MY Supercharged
0cj0 Member Since: 14 Apr 2011 Location: York Posts: 61 ![]() ![]() |
![]() I know exactly what your on about. Used to wind me up no end! |
