![]() | Home > In Car Electronics (L322) > 02 Vogue |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35535 ![]() ![]() |
if you get an amplifier , you'll boost the static as well....check the connections , you might find by cleaning them the signal might improve... ... - .- -.
EVOeng Member Since: 14 Sep 2011 Location: Surrey Posts: 225 ![]() ![]() ![]() |
It may be worth considering an upgrade to DAB. |
Rob750 Member Since: 10 Oct 2010 Location: Epping Posts: 18 ![]() ![]() |
Thanks Guys , Looking at DAB Upgrade Regards
have you checked the connection on the window, they are very lightly attached,it may of come off also there is signal booster,have you checked that.. V8 facelift Range Rover Autobiography 22" wheels.
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16315 ![]() ![]() ![]() |
+1 Check the signal booster...
