Home > Technical (L322) > Parking sensors inop |
netsonic Steve Member Since: 06 Oct 2010 Location: Sussex Posts: 165 |
I repaired mine awhile back, and found it was a combination of some faulty sensors and a faulty PDC unit, its common the PDC fails to the front as mine had so I bought a second hand PDC on e-bay and replaced all 8 sensors and now works perfectly. If everything on yours is dead not sure it’s the same issue as mine but you say the PDC is ok how did you test this and are you getting any beeping from the sounders front or back |
13th Jun 2012 7:17pm |
highfellzippy Member Since: 20 Aug 2011 Location: Yorkshire Posts: 153 |
i am lucky my wife has a vogue swapped units over
13th Jun 2012 7:33pm |
Pedrochellie Member Since: 23 Feb 2012 Location: Surrey Posts: 82 |
Does anyone know how/if you can test a PDC module? (unfortunately I don't know anyone round my way with a FFRR to do a swap check with - anyone near Addlestone, Surrey??!) My front sensors stopped working but back work fine? FFRR Vogue 2003 4.4V8 - Epsom Green & Ivory
14th Jun 2012 6:14pm |
If the whole front end is dead and no front sounder it sounds very similar to a well known fault on the PDC that means the front sensors stop working, can’t really test it unless you have a spare that works but there are quite a few on flea bay for £50 ish.....I bought one second hand 2 years ago and its been perfect ever since |
16th Jun 2012 4:39pm |
highaltitud3 Member Since: 13 Jul 2011 Location: Alpine, TX. Posts: 3 |
Try this:
19th Jun 2012 2:11pm |
Thanks guys
19th Jun 2012 5:27pm |
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 |
i know it's maybe not much good to you, but if you can find a garage with Autologic, you can test the whole system from that.
19th Jun 2012 6:59pm |
When you put in reverse gear, where does the beep come from? Front or back? If it comes from the back, the problem is with thee rear sensors. |
20th Jun 2012 8:40pm |
roger 47 Member Since: 24 Aug 2012 Location: Exmoor Somerset Posts: 80 |
Hi all.
25th Sep 2012 11:49am |
Budgie Member Since: 09 Jul 2012 Location: Stornoway Posts: 267 |
25th Sep 2012 12:58pm |
Thank you Budgie. Very useful. |
26th Sep 2012 12:04pm |
Tomw2000 Member Since: 22 Jan 2011 Location: Hertfordshire Posts: 202 |
I've a MY11 TDV8 and also had the rear parking sensor fail in the past - was sorted at the last service under warranty.
26th Sep 2012 4:05pm |
Bob the B Member Since: 10 Jun 2011 Location: Newcastle upon Tyne Posts: 163 |
My rear sensors are not working but the front is.
27th Sep 2012 4:19am |
Update from car going back to dealer's yesterday: In my case the sensor thingy has failed due to water damage. Lol, what 'rain' - we've not been wading in it.
28th Sep 2012 8:13am |
