Home > Technical (L322) > Urgent Help Needed Thanks! SOLVED! |
Pedrochellie Member Since: 23 Feb 2012 Location: Surrey Posts: 82 |
UPDATE 2 - ok i think its the heated steering wheel button control - three pins - green, yellow and blue - I have clipped the plastic side bit off so it will fit the new wheel connector and the green, blue & yellow wires follow through from both connectors (male and female) so that must be right.............! FFRR Vogue 2003 4.4V8 - Epsom Green & Ivory
2nd Jun 2012 5:22pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Swap the small black box in the bottom of the wheel over as the later 2009> box has the wrong connector...
2nd Jun 2012 5:50pm |
Thanks Craig - in the end I just snipped off the tab that was in the way and connected it up after checking the wire colours matched through!
2nd Jun 2012 6:13pm |
DeRanged Rover Member Since: 16 Feb 2012 Location: London Posts: 379 |
How long did this take to do and is it something that someone with limited mechanical ability (and confidence) could attempt? African Bush Junkie ... in London!
3rd Jun 2012 10:30am |
dave.s Member Since: 01 Nov 2011 Location: Isle of Wight Posts: 127 |
very easy to do, have a look on powerful uk web site video shows how to.
3rd Jun 2012 11:03am |
Hi DeRanged,
3rd Jun 2012 3:02pm |
