Home > General > Fuel Con |
piecost76 Member Since: 19 Jul 2010 Location: Nr Sevenoaks, Kent Posts: 296 |
Full service first - genuine parts from Dan@Duckworth on here:
24th May 2012 7:24am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3978 |
Fuel leak when driving? |
24th May 2012 7:41am |
Good quality oil.
24th May 2012 7:46am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35406 |
your service might have done a proper reset on the fuel consumption computer so the best way to find a 'real' average mpg is to do a tank to tank fill... ... - .- -.
24th May 2012 8:10am |
DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027 |
I recommend fuelly - it will show you real world figures. Land Rover Addict
24th May 2012 8:30am |
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 |
Mine has dropped too, not quite sure what thats all about. |
24th May 2012 9:42am |
...more strain on the engine because of more use of the a/c ? ... - .- -.
24th May 2012 9:44am |
I'm not sure Stan, i haven't used it this week when its been pastie boy hot. Been on the ped. Just generally the mpg has dropped recently |
24th May 2012 10:28am |
dont engines run better with cool air for combustion rather than hot...could be the reason maybe ian.. ... - .- -.
24th May 2012 10:41am |
Mikeyjd Member Since: 14 Jun 2011 Location: Wrexham Posts: 543 |
My consumption dropped a few months ago. Problem was a seized brake calliper. No longer FF owner but still interested. Present car Jaguar XE
24th May 2012 6:01pm |
Fuel consumption goes up in the winter months |
24th May 2012 6:21pm |
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 |
stan... does the cold dense air not just give better combustion and a bit more power due to a better burn? hence the reason that jap car tuners fit large front mounted intercoolers to ram as much cold air into the system as possible.
26th May 2012 8:22am |
you could be correct stu, but if the combustion is more efficient then you need less fuel to get to required speed.. ... - .- -.
26th May 2012 8:38am |
good point well presented!!!
26th May 2012 9:03am |
